Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Pirate88179
Fausto:
Great results!!!!!  This is incredible. Thanks for posting the lastest pictures.  Keep up the great efforts.
Bill
Bruce_TPU
@ Fausto
Your circuit indeed may turn out to be more efficient.  You have your lights steady on, and not blinking.  This would be very good indeed for a number of applications.  I look forward to your making it work with Dr. Shifflers barium ferrite coil, as I have 7 of those on hand.
The batteries amperage must also be tested and compared.
Holiday Cheers,
Bruce
plengo
sorry guys. I just could not resist after all it is almost Christimas.
Fausto.
plengo
One more thing. First picture is probe 1x at gate of mosfet with 5us Time Div at .5v Div. And second picture is same signal at .02us Time Div.
Fausto.
hakware
@plengo
Is that your last schematic diagram or is the newer one you were talking about. and could you re-post your most current schematic diagram to this circuit as well as showing how your hooking two of them up. also does the second circuit run without a battery in line? I just want to keep the smoke factor down when I build this. Thanks
