THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
Bob Smith
Turbo, I like it :)
I'm going to hypothesize...
Pulse a single strand of wire and you get a kick with a longitudinal impulse.
Insert 3 taps - say, 120 deg out of phase - and pulse them, you get kick-kick-kick.
If you can collect the longitudinal impulses coming off these kicks and dump them into a cap, it would seem to me you have some serious charge at your disposal.
Am I moving in the right direction?
Bob
Magluvin
Quote from: Turbo on November 02, 2016, 03:26:16 PM
Tesla states that you can have all kinds of electrons flowing through a wire traveling in different directions relating only to their potential power source.
He even said that you could have different electron flows through a single wire completely separate from each other.
I tried it and he is right!
I had thought of that before.  Say we have a wire 5in, and a AA battery on the left side of the wire, Pos at top, and a similar batt on the right side of the wire, pos down.
If the batteries are in a polarity position that when connected to the wire in the middle that each would produce a current in the wire opposite of the other, then the batteries are essentially in series! ;) There may be no or not much current in the wire at all as the batteries are in series.  There is no way to isolate them in the least if both are connected to the wire at the same time. Now if one batt is low on charge, or just different batteries, then there may be an imbalance where current most likely would flow in only one direction in that wire by way of the strongest battery potential. This is just my thoughts and opinion so far as I never tested it as it seems correct.
Now when it comes to complicated signals like cable tv and such, there would most likely be some nodes, in an instant of time, where electrons are poised to be flowing this way, and in another node electrons poised to flow flow the other way and nodes where the electrons are say at rest.
Mags
Turbo
Quote from: Magluvin on November 03, 2016, 12:45:52 AM
Mags
Dear Mags,
You are very close.
However the two flows are completely separated.
I am not much of an artist but i have drawn a simple sketch for you of what it is suppose to look like.
As you can see in the image the two flows happen on the same single wire, completely separated from each other.
This only incorporates the clean DC components.
When you replace the batteries you mentioned with switching elements you will then be able to generate high voltage and rf components that do cause interaction between these coil sections.
Then you will be able to generate the interaction Steven mentions in his writings.
Especially when your switching frequency is somewhat related to the resonance frequency, or a harmonic of the coil you made.....
So as you can see in the schematic the batteries are not in series, this is where you (have to) leave that textbook.
I noticed the arrows are drawn wrongly, but i hope you get the point.
If you have any more questions let me know.
MasterPlaster
What happened to sequential.9 and his posts?
ramset
S9 was playing outside of his Box and making a mess of other threads ,Stefan gave him many chances ,
he is on a time out....
*he does keep reincarnating himself  .
if you truly wish to engage him I believe an Email can be found ?
Thanks Grandma
