This is a, in theory, a working magnet motor. VERY cool!!
Started by Low-Q, November 14, 2007, 09:54:53 PM
Low-Q
Hi all,
I found this on the internet: http://www.geocities.com/k_pullo/SMOT15_PM3-3.htm
At least the first motor is actually putting out positive torque in 95% of the samples done (I haven't tested the other one yet). The original LUA script has a resolution of 0,05 degrees in 24 degree measurement. However, there is 16 magnets in the rotor which should give 22,5 degree measurement, but a modification down to 22,5 degrees also shows the same result. Even a 360 degrees measurement, with 0,5625 degree resolution (0,5625 = 9/16 - the number of outer and inner magnets) give 95% positive samples, with an average of 2,5Nm with peaks up to10Nm and dips down to -3Nm. No matter how I calculate the samples I'll get a significant positive result.
Vidar
TheOne
The link is not working for me, is the link is now down?
hansvonlieven
Yes Vidar, the site is gone,
would it be possible for you to post what you have on the project here so we can have a look at it?
Greetings
Hans von Lieven
karl
Hi,
avoid to make the mistake to add discrete momentas insted of integrating the functions of tourque and add them.
My opinion without seeing this device: sumM=0.
Why: the peaks contain more area between the lines than the lower values.
See eden project magnetic therory.
Good day
kaRLfunkel
Pirate88179
Yet another "working" device and yet another link gone?  I think I am starting to see a pattern here. I am not saying MIB but, after dealing with the info on xpenziv's design, this is getting old.  for once, I would like to see a design that works, and can be replicated, and, the designer/inventor says..."here is how you build it.'  Am I asking for too much?
I don't mean to jump to any conclusions because, maybe the link is bad or a server is down....that happens.  I still have hope.
