Some thoughts on how the TPU might work.
Started by dfro, November 26, 2007, 07:43:29 PM
Newton007
I have been reading a lot of posts here on this whole site and I am starting to see that this TPU thing is really gone wild.
It seems that it has really went so far out from the original concept that is has taken on a life of its own.
Here is something too. Just think of all the coils of wire that were ever made in the world. There must be billions made over the years in millions of different configurations.
I wonder how many of these unknowingly hit the "magic" frequency under certain conditions?
For example how many appliances, motors, TV sets, radios, automotive, anything electrical with coils of wire, for no apparent reason just burn out one day?
Or even a spool of wire at the hardware store that someone cut five foot off of and hit the "magic" length causing a fire one night of unknown origin?
To me induction is induction no matter if it is a transformer up on a pole or in the starter motor in my Ford.
If there is a alternating or pulsating magnetic field or fields strong enough, it can be, with the correct Length of conductor in the right configuration picked up and detected.
This seems the place to start when working with a TPU like device. To me any way.
Just wondering at 5:45 AM.
Grumpy
The concepts keep getting wilder and wilder.
        -Frank Edwards
Newton007
Well right, I am saying that the correct length of wire will be inducted into from a source of electromagnetic radiation of the same frequency, (I think this is what I am saying)
Yes I am saying that is where I would start is with a long spool of wire in a coil and the cut off a little at a time to "sneak" up on the correct length.
I don't think just measuring at different points along the wire would work, but might at  I think so too based on something else I am working on.
The inventor being a TV design engineer knows full well about horizontal output fly back transformers and how they work. If he did not,  he would not be much of a TV electronics engineer to me any way. So I think some of that is incorporated in his design.
But that is later.
Just like he said you don't want to hit the correct length of wire dead on or you could blow your self up if the two ends of the wire were shorted out. Just like you would not want to climb a power pole and short a screw driver across the secondary terminals of a transformer. Even a volt meter could blow up with the right amount of over voltage.
Also too, he said to start out small, with small gauge wire so if you are experimenting around and happen to hit the frequency the coil wires would just burn in two, without exploding. The same difference between shorting out a small 9 volt battery with a screw driver and a distribution transformer with a screw driver on a power pole.
I am saying that this is what I think is going on with the inventors device. It is not everything thats going on, but it has to start here first.
The cart has to be behind the horse or it won't work too good.
I hope this helps.
Newton
AhuraMazda
What would happen if you had a coil for which XL = XC?
EMdevices
Eldarion, nice post.
If we get a hold of this paper we might learn something:
http://www.osti.gov/energycitations/product.biblio.jsp?osti_id=164989
EM
p.s.  ahuramazda, all coils self resonate at a particular frequency  (where xl=xc)
