What to do if one works?
Started by Blainiac, November 30, 2007, 08:28:54 AM
pese
ResinRat2
Hi Blaine, Hans, Pese,
The experiment that Hans is referring to ran for a total of 20 days continuous and was used to develop the methods required to run the hydrogen generator for a long-term period. It produced a small amount of power, enough to run a fan and regenerate a zinc electrode, and initially gave results that indicated overunity. Unfortunately, as which is common with research and development prototypes, the unit's performance was dropping by the end because of the electrodes crossing inside the reactor. This was due to poor design of the reactor.
In my opinion it did not show definitive overunity. It needs to run for months, preferably years, to show that. This was not achieved in that generator; but the results were promising and helped to give the modifications required for a unit to work long term.
I am in the process of assembling a reactor that holds about a gallon of water and is made of glass. Everything I learned with the small reactor will go into this large one and the performance should be improved. If overunity can be achieved, then this next unit should be able to show it. As a scientist I need to look at it as objectively as I can, which can be difficult at times. The tungsten/carbide electrodes are not cheap. The fuel cells are expensive, and the chemicals are hazardous. It needs much more development before it is even ready for general use so there is still a long way to go on this one.
Despite the difficulties and disadvantages that are showing right now, it does look very promising and needs much more work to prove its worth. This I am trying to do as best I can with my limited budget and time.
These are my thoughts on it; but Hans is right. I haven't seen any goons, but I also haven't produced anything that looks like it would solve the energy needs of the world either.
mapsrg
What to do when one works...? show the world with all the detail needed to reproduce it
giantkiller
Quote from: mapsrg on January 20, 2008, 01:44:49 AM
Do what the PKware guy did. Make T-shirts with the technical info on it and sell or give them away.
--giantkiller.
spacecowboy
O-U might be simpler then you think, and a simple fact of nature itself if you look into it deep enough, maybe some of my other post might help.
