Bedini replication in Germany
Started by albert, December 08, 2007, 05:08:57 AM
pese
Quote from: albert on December 13, 2007, 02:22:30 PM
I use a small power supply to charge single gel cells overnight and can bring them up to 17, 18 volts. the Nato cube will go to 15 volts. albert
This Batteries must no be loaded higher than 14,4 volts.
Normal way  they will then beginn to boiling .
Dangerous and you damage the devices.
If the battery is loaded to 14,4 . than they ist 100% loaded .
You must stop the loading current . or reduce to an holding charge from
a few milliamps only.
Gustav Peset
Ren
gustav, Albert isnt using a conventional method to charge this battery to that voltage. An estimate of the amps flowing into his batteries would be in the milliamps, perhaps even as low as 50ma. His battery will remain dead cold, hence the term cold boiling and You'll probably find it doesnt cause the damage you would expect from a conventional charger loading it this high. Bedinis unique method of recharging the battery is unexplainable by conventional science, and experimenters often find an increase in capacity and powering times after several cycles. So his 7 amp hour battery might behave like a 10 amp hour.
I am not saying that its necessarily a good thing to charge the battery to these levels, but the fact remains if it was a conventional charger Albert would be soaking acid up all day by now.
Perhaps you already know all of this and you are still issuing your warning, which is fair enough I guess.
hansvonlieven
Quote from: Ren on December 14, 2007, 02:54:13 AM
By the way Hans, if that avatar is a pic of you, you're the spitting image of my mates dad! I cant help but apply his attributes to you! (You're not a VB drinker are you, as this would be too freaky!) :D
The picture is really me and yes, I have got a VB in front of me right now :-)
Hans
helmut
Hello Albert
I had also startet a Replikation.It is to try several Coil Setups
