I HAVE ACHIEVED OVERUNITY
Started by noblefuse, December 11, 2007, 10:15:21 AM
Goldsphere
The Tesla coil in the video, all the Tesla coils I saw in the video are not fully tunable.
They look like they resonate at between 160-350 kHz, 160kHz being the larger one in the video.
The potential voltage appears to be about 200-300 kV.
I see now that you meant 256 thousand volts!
I see great difficulty in making a Tesla coil that resonates at 1.42GHz and produces 256 kV, in fact I know that this is impossible. Imagine a Tesla coil 3mm in diameter with 5 turns on the secondary putting out 130mm sparks.
How are you measuring the output? only on the gamma detector?
And for the rest of you, pull your head in and discuss the topic!
Schpankme
Quote from: noblefuse on January 22, 2008, 04:30:44 PM
i came to discuss science
i believe also with full conviction
i come to a forum of science for one main reason-to enlightnen my fellowman
i have done something alone
i fundamentally believe
i only ask someone in this internet world who hears my words
i do not expect you too
i touched upon in pdf and many other sites of noblefuse-
NobleFuse Corporation For Nuclear Fusion
Supporters
At some point in time when the total number of people  reaches a synergistic level this idea will finally have been accepted as a viable form of alternative energy, . In doing so, it will be scrutinized far greater to actually verify it's fantastic significance.  Let this supporter list also serve as a petition by free citizens to begin a clean FUSION PROCESS.
The idealized structure of the company Noblefuse:
Noblefuse will be a non profit company with one mission-
With the implementation of a clean fusion power plant
there shall be a modern hospital facility to the standards of an Albert Einstein medical hospital and a ST. Jude children hospital built in every city of every nation
JOIN & receive one free share of Noblefuse stock
Copyright  www.noblefuse.com 2006-2007
http://www.noblefuse.com/supporters.htm
- Schpankme
"one point twenty one jigawatts; 1.21 jigawatts" - Back to the Future
noblefuse
gentlemen- my apologies- it seems my video and pdf and the fact a tesla coil made to stabley resonate upon the dielectric of pure water dope with deuturons was not enough to convince others to seriously investigate- i thought it was- but then again-it is simple for me to see as  i have conceived of this magnetic pinch idea since late 2002- i tried to rely this info to sandia labs and los alomos - but they are busy with hot fusion and z pinch- so i stayed alone and continued- without putting sugar on it- the more you really look at the mechanism- you will see its simplicity and effectiveness-
1. i used dc motors from a buick century driver seat in order to make the spark gap- primary coil about secondary coil movable/tunable/- and also a movable coil of inductance in line with the primary coil-only several microhenries as many would know- i hand built many versions of the coils-and made each one resonate upon the load-
we all know any load will have a resultant impedence- and accordingly apply a ac signal to it- in this case- an ac signal made to cause dielectric breakdown(the lightning bolt) and conduct upon heavy water- why heavy water- for two thirds are the fuel the entire fusion community is trying to fuse- it is the best candidate- and it lies perfect as a water molecule and its obvious benefits as a controlled liquid in pressurized vessels is apparent-- however- i seen positive results with standard ultrapure water- why- i see signs of the Oppenheimer -Phillips process is regards to deuteron production- i note in pdf- ultrapure water is our baseline- then dope it with heavy water for deuterons- also- any element under nickel iron 56 may be found to be used as concentrations within liquid
2.  to understand this mechansim- ignore the driving force for now- again-the thought experiment i gave by einstein- the fuel is between electrodes- it doesnt know what power source it is- however- we know it is a tesla coil- a tesla coil has the ability to make extremely large voltages and somewhat of a high frequency- khz range- i have simply taken a tesla coil for its use of high voltage to cause dielectric breakdown and cause plasma conduction- i am saying 750 kv is my theriotical number for the beginning of strong and observable efficiencies- dont care about current here- or poloidal current- lets just look at voltage gradient- ok- now frequency- yes- once this coil is tuned- it is fixed- and i mention a possible resonate frequency of 21cm- but that is speculation and have said so and the gentlemen who mentioned the joy of building one- so have i-- however- even with the khz range- it yields the desired effect- remember skin effect- it is the nature of high frequency and it principles which cause currents to flow to surfaces and cause constriction of plasma- this is magnetic pinch ideology- established for many years and nothing new here- yet- it is the use of high voltage high frequency which is causing the oscillation of charged particles in plasma of water which create the condition
to slam two hydrogens together
i am now going to make a statement and please do not be insulted by it- as it has happened to me--- rubbing two sticks to make fire is as simple as you can get- imagine not knowing then seeing- its an awakening- once you see it- you are positive to it and do it- however- did anyone actually try to rub two sticks - it is very hard- right material- right process-etc--
someone earlier said all you are saying is a tesla coil in water- yes-
  the trick is merely understanding the mechanism i am trying to initiate for excess energy-
i am after the magnetic pinch to cause fusion of elements within this so called lightning bolt
applied voltages upon a charged particle cause an intrinsic magnetic field upon that particle- look at cathode ray tube- the electron gets resultant magnetic field- thus we can then control it-
look at high frequency- does it not cause constriction of currents and skin effect- i talked about it in pdf- this is related to change in oscillation is change in velocity componet of applied signal and thus- velocity changes make magnetic changes- look at equation for skin effect and related-
however- simply take these two understandings as something we can build- the tesla coil- and apply to a fuel to try-
i did this upon the greatest material in the world- water- it is perfect as a liquid in a heat transfer mechanism as many know- however- it is perfect as a molecule in regards we can superimpose upon it- high voltage and frequency-
i exhausted all my funds (not to mention life)  hand building and testing alone this mechanism- and i have received positive results of fusion- since my time on net-all i say to everyone is - dont trust me- please replicate it so other voices will add to mine- and maybe create some public voice to have this built the way it should-
yes- the 300 million i mentioned is out of the box- i did so to stretch our minds and see how far we can go if applied to a commercial reactor- however- without question- even previously built coils of several million volts which have been built in the past may be used now off the shelf- we can use existing knowledge of standard tesla coils and place within vessel- to increase effiencies- we apply toroidal magnet about plasma arc- someone mentioned you cannot go to high as plasma conduction will increase conductivity- can someone see an applied magnetic field about plasma will introduce a magnetic resistance to plasma circuit- thus- voltage may still be increased- it is high voltage used conjointly with frequency to strike the required magnetic pinch-
gentlemen- i have boldly made the statement of overunity- i stand by it- i did not make a commercial power plant- nor a stand alone steam engine- i tried to show process- i try via paper- i try by risking my life and building it to show you the most simplest version of it- and then go from there-
i will keep on trying- but it is up to society to finish this- i cannot do anymore- my full time devotion to try and aid this energy crisis has left me broke and financially disadvantaged- and to make matters harder for me- all my talks of god- yet-i believe- therefor i am
i will not write again- as i see it is more important to make another video and explain further- i do not like typing- and many things are taken out of context- as you all know-
however- if you are sincere- find me at my website of noblefuse
god bless all of you
Solomon
Bessler007
Someone in another thread went a*ranting about the harmlessness of cranks looking for a cure to the energy crisis.  Well, is it?
Or is it "just getting your jollies" to strenuously suggest one do as exhaustive of an analysis possible in their spare time with very cheap paper and free pencils before they go full bore building 1/2 baked ideas?  I don't think so.
Although it's no skin off my arse (yes, I went for the arse again) it's sad to see.
Bessler007
mib HQ
Quote from: noblefuse on January 23, 2008, 09:36:20 AM
http://www.bessler007.blogspot.com
Please try again. If you come back to this error screen, report the error to an administrator.
AhuraMazda
@Bessler007
In case you missed it, we are back on technical issues now.
