I HAVE ACHIEVED OVERUNITY
Started by noblefuse, December 11, 2007, 10:15:21 AM
noblefuse
thank you Ironhead for your support- you have without question- identified my true motive- i have surely been beat up over these past 10 months- it is expected-yet-when you have always been sincere and honest your entire life- it is sometimes hard to continue communication-
this is a big prize- and will take many to finalize- i do not want to be arragont in my statements- it is truthful to state this is a new mode of science- i see it completely as the marriage between hot/cold fusion-
as for tinu- thank you for your statements- my writings are scattered and paint the entire picture with time and patience in conjunction with the fact that a stable arc may resonate upon heavy water- my pdf has several version- yes-drift current velocity is not equation 4- but some fraction of it- not the same as in solid conductors- nor even plasma state of todays tokamak devices-
also- the 300 million volts and 1.4ghz is provided for parameters to investigate-
i built many variations- and you will see positive results with simple setup i have made- but commercial production within a reactor- we must sweep all parameters for optimum conditions/ pressure/electrode spacing- voltage- and external magnification about plasma arc for additional pinching-
there is much to say- but i am trying desperately to have combined voices- this will only happen when someone else will do the same experiment- use your measurements- who will believe mine- my sincerest wish is we all come together and force by public pressure to have Westinghouse/ or some nuclear power company- do the same thing in a complete perfect vessel built for high energy flux already and give it a good try -i made the  primitive caveman two electrode system- let us address it with enthuisiam-
gentleman- this is the possible true home for the tesla coil in regards to giving unlimited energy- the lightning bolt- water-
Solomon
redriderno22
hello, first post on over unity
noble fuse is on the right track
if the electric model of the sun is correct, he is.
it may not be over unity but a clean source of power.
if you haven't herd of this theory about the sun look it up.
if the sun has a high positive or negative charge and space the opposite then this is possible.
high potential difference and magnetic pinch,,,,,think about it
the corona of the sun is hotter than the surface....by far
so this must me where the fusion occurs.
i dont think its due to mass alone.
noblefuse
thank you- i have thought of the electric discharge model myself as a means for sun fusion- or even internal earth?? these are speculations- all i know is out of a theory i derived from einsteins special theory of relativity in which i see the power to slam hydrogen together by strong discharge model and stable oscillation of an electrical source(tesla here) and hand built my own tesla coil at 1 million volts to prove my ideology- i am lucky to survive the experiments as everything i did was alone- in 11 months of only trying to relay this information i have been attacked as a scam- i never asked for money- what is disheartening at this stage is i see noone at least give me some recognition for this- even Princeton labs is stating some kind of electric arc in water just recently- as i tried to communicate with them for years- simply because i do not write in their fashion- i am ignored- i have no credentials except engineering degree- thus - i am dismissed-
i have tried to  stand as a vaudeville actor and present myself in many colorful ways to attract attention to this science- yes- some of it unorthodoxed- but - it attracts more so than just science alone- i assure all as i have been trying to relay this since late 2002-
electromagnetic fusion
time will tell
Solomon
redriderno22
one question?
did you sample the gasses produced in your tests?
did you get any helium? or just hydroxy?
also i noticed you joined oupower, but no posts yet?
redriderno22
