WHAT IS ELECTRICITY?
Started by nightlife, December 16, 2007, 09:00:49 PM
mapsrg
electicity can be created chemically as in batteries ;electricity can be created with solar cells;electricity can be created with a generator spun by water,wind,steam with the use of turbines.The generator uses magnets to do this.No circuit no flow of electricity.................but you can have static electricity just waiting for a circuit which may be created with friction.
Electricity is modern life and without it civilisation would basically collapse....free electricity with no pollution and no limit is our goal.Energy is life....
nightlife
 My conclusion from the research I have done is that electricity is nothing more then a resistance creating and causing the flow of a vibrating frequency. the stronger the resistance, the faster the vibration. The faster the movement of resistance, the faster the flow of the vibration. The larger amount of resistance, the more amount of the vibrating frequency.
Electricity can be transmitted and received, the same with a frequency. Crystallized fossils can be used to attract electricity, just a a frequency can. Magnetic fields don?t attract electricity and they don?t move electricity, the same with frequencies. Electricity is attracted to all metals, just like frequencies.  Electricity is made from rubbing things together, just like frequencies. Electricity can create magnetic fields, just like a frequency can.
Based on that and knowing we have frequencies all around us, all we have to do is design something to receive them. There are said to be three different vibrating frequencies all around us and those are the ones we must attract.
First we have to find out what they are and then we have to find out what they are attracted to. Once we do that, the rest is down hill.
nightlife
mapsrg, thank you for your comment but the question is "What Is Electricity/" not what are the different ways to make it. I am sure we are all aware of the different ways you listed to make it.
Please review the other comments and you may see what i am talking about.
Thanks again though for at least getting involved.
Evil Roy Slade
These are the three frequencies you seek.
20khz
69Mhz
181Ghz
ERS
I thought I was wrong once...but I was mistaken.    Oscar Wilde.
wattsup
@nightlife
Thanks for your explanations, but what about this then.
To spin, you need to have first something or somethings to spin. Now if those things that are spinning have a physical nature, then they are little magnets.
As for resistance, you are using this term without describing where or how or why this resistance is generated. And without explaining what you mean by "flow of resistance".
If resistance is the result of two opposing forces or the result of a dynamic force against a static force, then you first need those forces. A generator runs into resistance when it produces electricity. I call it drag. But again, this resistance is the result of magnets.
Maybe I do not understand your term "resistance". Or maybe you need to find a better word for what you mean.
