WHAT IS ELECTRICITY?
Started by nightlife, December 16, 2007, 09:00:49 PM
0ne
Quote from: mramos on December 17, 2007, 10:05:22 PM
I must admit I enjoyed what I have read.  Very creative.
I like you 0ne (who uses a 0 in his name) and thinks the world is binary.  We can relate there.  on or off, 1 or 0.  No gray/variables in there.
Thank you friend.
Yes everything is binary, 1 or 0, yes or no. A complex system of yes and no is what creates everything.
But I have to ask.  REASON FOR THIS POST, if I take two magnets and click them together (n/s of course) I get hydrogen?  So two spinning magnets on a wheel passing will make an H generator?  I like that idea.
Not exactly. When I say "click two magnets together" I am talking about protons and electrons. Hydrogen is made of 1 proton, and 1 electron, those are the magnets. According to todays knowledge, you have electrons flowing through your wires, and out of outlets in your house. Electrons are naturaly attracted to Protons, that is why almost all elements have the same number of electrons as they do protons, they are almost always together. If you can allow only 1 electron to flow through your wires, and meet with 1 proton, you can make hydrogen.
There IS a way to make hydrogen with just "electricity". Like an electric powered fire. If your circuts are correct, and your timing is correct, and your wires are REALLY THIN, and you use very little power, and you learn the structures of all elements, you can build all elements by simply connecting protons and electrons together like magnets, with "electricity". This renders all elements worthless, because you can have unlimited quantities of them. Gold will be just as valuable as sand.
The key is your switch. How fast do you need to switch the power on and off, so that only 1 electron flows through your wires? How small does your wire need to be, to allow only 1 electron to flow through? NANOWIRE??
http://harvardscience.harvard.edu/node/7623
....to be continued.
IronHead
Wow , I find it fascinating for people to learn what has never been tought.
So many different ideas here. Most interesting
Quantum relationship  is more like a thought than a thing.
0ne
Quote from: nightlife on December 17, 2007, 10:19:33 PM
mramos, Keely was said to have made large amounts of Hydrogen of two drops of water. Have you read about any of that and or how he did it?
I believe he tapped in to some vibrating frequencies that are either being held from us knowing about and or he him self took them to his grave. I believe these vibrating frequencies are the key to all our energy problems.
Let me tell you all how to PERFECT electrolysis.
Two magnets with different resonant strengths are attracted to each other, but not as strong as two magnets with the same resonant strength are attracted to each other.
If you want to effectivly split H2O, your cathode and anode must be different resonances. 0ne must be the same resonance as hydrogen, and the other the same resonance as oxygen.  This will make sure hydrogen is attarcted to one side, and oxygen attracted to the other.
Matching resonance is key. When you tune a radio to a frequency, you are turning the antenna into a magnet with a certain resonance that only attracts the magnets with the same resonance.
nightlife
 Grumpy, I think a movement has to be restricted to form a frequency. Therefore a frequency would be a resistance of a movement. Once something is created, everything it touch's becomes a resistance. Either a positive and or a negative depending on the attraction and detraction.
This same theory could and should be used with light as well as magnetic fields. We have to start with something before we can create anything including magnetic fields.
A spin creates a magnetic field and a movement creates a spin, but movement has to have a resistance to create a spin.
Grumpy
I'm sure it has something to do with how things are made manifest in our reality.
        -Frank Edwards
