How to produce electricity
Started by nightlife, December 21, 2007, 08:23:39 AM
nightlife
 My whole point of starting this thread was to show everyone that electricity can be produced by collecting natural frequencies because frequencies are part of what electricity really is. Frequencies can be collected using one and or the combination of all ferromagnetic elements for the attraction and or a north end of a magnetic field will supply the same effect and the south end of the magnetic field will repel it or in other words, push it.
Magnetic fields act like a vacuum, the north being a suction and the south being the exhaust. They will use the vacuum effect on all ferromagnetic elements as well as a frequency but it will only use the exhaust effect on frequencies.
Magnetic fields act like a turbo for the flow of frequencies, the stronger the field, the stronger the flow.
Only certain natural frequencies will work and thanks to our government, we are not allowed to experiment with certain ones. That?s not a bad thing though because if certain ones are created and intensified to much, they can create disasters.
This next link video clips are of a text done on a bridge using frequencies.
http://timber.ce.wsu.edu/supplements/seismic/Images/tacoma1.qt
http://video.search.yahoo.com/video/play?vid=1077849250&vw=g&b=0&pos=2&p=frequency++bridge&fr=slv8-msgr
Those videos show you how strong frequencies vibrations can be made, Everything substance has a frequency vibration limit based on the frequency that created it. Every substance can be torn apart by just using frequencies.
If you do a search, you will find others that have done some interesting experiments using frequencies.
I honestly don't think many know of the possibilities that frequencies have in being utilized as a main power source. I do know the government knows but look who runs it and that is why I believe that most don't know about it. If more did know, people would build receivers using magnetic fields as a power source and big money would lose all those big profits.
Localjoe
Quoted from nightlife "Those videos show you how strong frequencies vibrations can be made, Everything substance has a frequency vibration limit based on the frequency that created it. Every substance can be torn apart by just using frequencies."
-Dude once you understand whats going on in the heterodyning thread maybe you will just read from that point on and not post such meaningless things .. you obviously have the ability to type www.google.com if you can post all this crap.
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
hansvonlieven
Quote from: nightlife on December 21, 2007, 08:23:39 AM
G'day nightlife,
You obviously suffer from a number of mis-conceptions about the nature of electricity, magnetism and oscillations (frequency)
These things exist independently of each other and only are associated with each other under certain conditions.
For instance, a sonic pressure wave at ANY frequency has no electrical or magnetic phenomena accompanying it. You can level a sound wave at, for instance, a piece of glass and shatter it, without causing any electrical or magnetic phenomena to occur. There were no electrical discharges or magnetic disturbances when the Tacoma Bridge collapsed.
There is no electricity whatsoever associated with a permanent magnet. No discernible electric field has ever been discovered around a permanent magnet.
There is no magnetic field associated with static electricity. You can charge up an electrophorus with static electricity and attract a dielectric, like bits of paper, with it and have no deflection of a magnetic compass needle. Try it for yourself, take a bit of plastic, like a comb, rub it with wool and pick up tiny pieces of paper with it next to a compass. It will pick up the paper but it will not show a magnetic field.
There are no discernible oscillations in direct current ( DC )
There is no such thing as suction, there is only differential in pressure. It is the pressure that fills a vacuum, not the vacuum attracting something.
All the phenomena you are talking about come about as the result of an interaction between these forces.
For electricity to generate a magnetic field it has to flow! For a magnet to generate electricity it has to move against something!
The forces themselves exist independently of each other.
Hans von Lieven
0ne
Hans von Lieven
The reason electricity has not been found in most of the case's you describe, is because "electricity" is TWO forces, not 0ne. Also, magnetism is TWO forces, not 0ne. When you have only 0ne side of each force, we do not have tools that can effectivly measure them. When the electron side of electricity is present, we think there is electricity. But when the other side of electricity is only present, we think there is none at all.
Same with magnetism. When both forces of magnetism are present, we have attraction and repulsion. When only one side of magnetism is present, we can't detect it at all. When magnetic force North and South are seperated, they are attracted to all things. You are all being fooled by what you can't see, and what you can't measure.
hansvonlieven
G'day one,
What you are really saying is "I think it works this way but there is no way to prove it"
That puts your theory into the realm of speculation.
Hans von Lieven
