Muller Dynamo
0 Members and 95 Guests are viewing this topic.
teslaalset
Quote from: Tudi on May 13, 2011, 10:38:33 AM
@Dbowling : Interesting. Now why did romerouk say that it might take a month to finetune the device ? Maybe there is a distance when he observed this lockdown effect ? Depending on the power usage he did mention you will need to finetune it. This power usage drains the coil thus removing the lockdown effect, or not ?
Mostly because the 'identical' magnets will all have different strengths due to tolerances.
If you fine tune for one rotor position, you can start over again for the next rotor position.
redrichie
Dont want to distract from the thread but I have been tying this to ED also.  ED described how to make a magnet and make a magnet stonger.  I have a feeling his PMH if used as a stator was magnetized and not just a bar.  and the coils were there to cancel out the magnetic field that was there.  Like the Radus boots and magnetic memory.  CAncel the magnetic field for a brief pulse let magnet suck in.  release pulse, let nature flow back in and repel magnet away.
starcruiser
what about the PM field from the nearby magnacoaster device, would that PM field have any influence on the setup?
Regards,
Carl
neptune
Just had an odd thought . Look at the diagram on page 2 , romero`s reply numbber 20 . Notice that the magnets on the stator are in repell mode to the rotor magnets . The distance at the closest point between rotor and stator magnets is probably about 25 mm .My question is , what stops the stator magnets flying off . does the washer play a apart . Has anyone got far enough in replication to know the answer?
nul-points
Quote from: neptune on May 13, 2011, 12:17:49 PM
hi neptune
yes, i seem to remember that R glued the washers down to the acrylic
the attraction to both the washer & the end of the core just beyond means that the magnet stays in place
hope this helps
have we met before?  :)  (LOL @ your new house name!)
np
[Edit: just tried it with two neos & some ferrite - works even without washer]
http://docsfreelunch.blogspot.com
