Muller Dynamo
redrichie
Not to mention LIdmotor is one of the most persistent experimenter I have seen.  He dont give up until he succeeds or the project is bunk.  Then he his innovative and works with a couple different things and comes up with something fantastic.  NOt only that everything he does is small and table top size.  Which I find incredibly difficult to do in most cases.  Usually when it gets his attention there is a good deal to learn from him.  Glad to know his name though.  He never volunteered it so I never asked.  LOL
lumen
I see others are pondering the operation of this device also, and why it would be OU when it's operation is typically the same as any other generator.  Is it possible that it's operation simply inverts the same laws that prevent generators from achieving OU?
Is it possible the real energy in not made when the magnet passes the coils, but when the magnets are leaving the coils. With the magnet at the coil, the coil is in netural flux, then as the magnet moves away, the field actually aligns with the magnet on the back of the coil and increases the field through the core.
If the increase in flux is resisted because of load on the coil it also affects the approaching magnet and rotation is still balanced.
If the coil is pushing or resisting the approaching magnet then it is also pushing on the exiting magnet.
If you go back and look at the field animation on a previous post you can see this effect with one magnet. It would have been clearer with two magnets.
LightRider
Quote from: duff on May 12, 2011, 10:58:42 PM
Audio Spectrum  Analysis of RomeroUK "Suspended In Air" Video
(first 20 seconds of sound)
Duff,
The Audio Analysis of RomeroUK "Suspended In Air" Video seem to show no sign of slowing down:
first haft :Green
last haft :Red
Full video :Blue
We see little change (slow down) from 165.5 hz to 159 hz [but no harmonic to confirm that.] edit...no true
53 hz Red and 55 hz Green
165.5 hz Red to 159 hz Green
Other analytical technique will be studied for more solid results.
LightRider
Dbowling
If you want to understand what kind of a difference adding a magnet to the end of a coil can make, take a look at this video of a solenoid I took out of a sprinkler valve just to play around with.
http://www.youtube.com/user/11Turion?feature=mhee#p/u/1/wvHzNg4MLQA
I wanted to see what the effects of the magnet would be on the coil inside the valve and how electricity would affect the magnetic field. If you consider that once a coil is fired in RomeroUK's machine with the magnet on the end of it, the coil is disconnected from and isolated from the circuit, and becomes much like this sprinkler valve coil. The magnet on the coil MAY be causing a similar reaction in RomeroUK's machine, which is to say, allowing the coil to remain in a specific state of magnetic attraction without the presence of applied voltage. Do we know whether the magnet on the end of the coil gives the coil the same polarity as the pm on the rotor, or is it opposite? I have been wondering if by giving it the opposite polarity from the applied voltage it is used to regauge the coil. There are a lot of possibilities here, and those of you who think there is nothing special about sticking a magnet on the end of a coil may want to think again. This is similar to what Ed Leedskalnin did with his Permanent Magnet Holder. If you're looking for WHY this machine may be different, here is a reasonable explanation, since what I show in my video "cannot be done" according to the laws we "supposedly" operate by in the world of electrical engineering. Just MY 2 cents worth.
David Bowling
k4zep
Quote from: lanenal on May 13, 2011, 09:20:12 AM
Man, that's huge. I'd say this increase can't sustain...soon much more people will start producing it -- the profit would be too high to refuse.
Problem is China controls/owns about 90% of all materials used to produce Neo's.  and is using almost all of it for internal use.   US is starting back up a mine/production facility in California I think, but as they say, 'Houston, we have a problem.
