Muller Dynamo
kEhYo77
@yssuraxu_697
The AC cap is connected like in A - parallel to all the coils. My rotor has got 3 magnets only and it is difficult to hit anything above 2000 RPM, so the frequency that hits the gen coils is up to 100 Hz. The coil in the middle, the choke, has a little ferrite core inside which bumps the inductance few mH up...
I have found that without the AC cap there is no acceleration in the range of operation. Adding a cap slows down the rotor and the acceleration gained with a short or a load is up to certain speed which is lower than the speed without the capacitor. So it is not very good in my my opinion.
Nevertheless I think that a high inductance - step-filar generator coil is the way to go with this...
norman6538
for those who don't have broadband here are my notes from Zerofossilfuel's 58 min broadcast
zerofossilfuel
  Here is a rebroadcast:  http://www.justin.tv/zerofossilfuel/b/288904233
It may only be there for 6 days.... so get it while you can.
He removed caps and light goes dimmer and rpms go up some  - 3900 +
added power factor correction cap in parallel to 2 coils and voltage went up abt 1.5v -
Zero says it looks real good..
5 ohm load kills rpms a lot
input current goes up with lower rpms
714hz for one coil..  9x8 magnetic events = 51kz
scope trace was drive coil
at 42 mins he predicts self runner by weekend
his coils look pretty big... not sewing machine spools
3800 no load 3810 bulb lit  11.95 volts
no tuning cap and rpms go up to 4780 but volts 10.43
no scope trace of output coils
Tudi
Quote from: d@rkenergy on June 28, 2011, 06:52:02 AM
If you make a machine that produces the free energy, can distort the balance of energy in the universe. and as a result can be a very big disaster ... is this true? :o :o :o
Balance ? Balance has a meaning if you could explain how the universe got created. You can create local balances out of nowhere without any proof that you cannot create it. There are countless non proved theories about this.
Produce free energy ? Well, if you could create matter and anti matter, that is also like creating energy, you just need to make sure the 2 do not null out in your lifetime.
Beware what you wish for !
xenomorphlabs
A friend of mine told me yesterday:
Do not try this works!
And your knowledgable "friend" bases his "warning" on exactly which quantum physics research paper he studied ?
Tudi
Quote from: norman6538 on June 28, 2011, 07:10:50 AM
...rpms go up to 4780....
at some point you can hear some alien sounds ( due to the microphone distorsions... ). I get this as a divine msg for success xD
