Muller Dynamo
0 Members and 164 Guests are viewing this topic.
electr0n
opps maths malfunction
"and coilB outputs 25v at 0.2mA = 5w" should be "and coilB outputs 25v at 0.2A = 5w"
its late :)
cheers
Tudi
Images show more then 100 words.
Tried to show what a coil ringing is and how important it is to be in resonance with your RPM.
- upper wave is your coil (+ other components) that WANT to resonate at specific frequency
- lower wave is how your SPECIFIC RPM will try to induce voltage in your coil
If you do not match up the 2 waves then they will try to cancel out each other. If you match the 2 waves perfectly then they will add up. You could use a diode to just pinch off some part of the wave and leave some ringing in the coil also. Some say that if electron movement have some inertia then leaving some ringing might be more beneficial then extracting it all.
- This is about "bolt theory". Where you have 2 waves that should cancel each other out as sum. BUT as information there is a lot of things going on and they are not NULL !. With this technique in theory you can avoid generating Lenz BUT at the output with the correct approach to separate the 2 waves and use them as you wish. I hope this image helps some people imagine a how a different out of the box approach could be made. Pls note that this is not exactly how ZPE was explained in some of the documents.
Tudi
Regarding Thane's video. Wondered since day 1 why Romero had he's wires made so "ugly", i mean i could have not done it worse if i wanted to do so. It's to be able to build up more voltage, to store energy in voltage instead magnetic field. I think this is the reason why the coils were taken away. Maybe there is a patent for such coil winding ?
baroutologos
@bolt & baroutologos :
Say we have 2 coils, coilA wound with litz normally and coilB wound bifilar with the wire mod (123 to 4567 in series)
If coilA outputs 5v at 1amp = 5w
which would have the most lenz lagging?
Jim
hey jim,
i am not the right guy for explaining technical issues but since you ask me, i would give you my view...
An answer of this question cannot be that straightforward. In your example case, the 300 turns 7 strands litz wire will out put some (say) 10 volts open circuit and 5volts at 1 amp (5 w)
By connecting it biffilar mode, it would output some 20volts +- open circuit and for getting those 5watts you should draw some 0.5 amp at 10 volt. (half amp double turns same result) Who told you that voltage in this topology will behave otherwise? Or in other words, will extract more power with less amp/turns counter flux - lenz creation?
On the contrary so far experience have confirmed this trade off and 0 net in effect change.
This is my view..
Dave45
Quote from: Magluvin on June 30, 2011, 12:16:21 AM
Hifi?  lol   hey Bruce, what is your coil, fityfi?   lol
I got my self laughing after my last post with this, and I had to post it, no harm intended, just chuckles.  ;]
Magfi
;D Mags I really like your atitude bro , and your right the possibility's are endless very exciting.
Im near finished with a project work related then Im going to spend more time on this.
