Muller Dynamo
0 Members and 137 Guests are viewing this topic.
Artist_Guy
Quote from: David70 on July 05, 2011, 06:28:35 PM
@Artist_Guy
assuming that it goes under the table that still not reslove the first video where I can see from the pictures posted just before, the cables are going to the motor.
How can you load a 20watts bulb but the amp meter is not showing it if it is connected to the battery we should have about 3 amp total shown there.If that can be answered then we know which direction we are going
Dave70, hi.
I don't have all the answers but can think of two potential solutions.
1) Model the device in Sketchup 3D, and overlay with video, etc, accounting for all wires. Repeat for each video. See what results. (I don't know the software well enough yet, or I would have already)
2) With a closely similar build, add the fabled wire X's to a battery and run all the same tests as shown in the self runner video #2, note results, similar or different. (I am not far along enough in my build yet, to do this either)
Even then such would only be suggestive, not conclusive. We are all in a weird place here. However without these Muller threads, I'd have nothing much to do. : ) I check them all about 560,329 times a day, hoping for a good positive result...or even just more truth about the one that started all this, good or bad.
Regards,
AG
plengo
Once again I am showing two short videos that CLEARLY demonstrate NO cables going to the cap of the table.
First video shows the cap at 99% clearance where one can see not cables going to it, BUT some argued that the cap is tilted. So second video shows what those "cables" are and one can see they are going to the closest to the front of the video's coil.
Please, just look at the short videos using a player that can repeat over and over again the sequence so that your brain can see that indeed there is nothing there on that cap.
I thought the cap was titled because I also thought the table has a glue line on it, but the second video shows that it is just a 3D tricky in the mind. The second video, if played many times, will convince you of the proximity of cables in relation to the cap way behind on the back.
Fausto.
short video one: http://www.overunity.com/index.php?action=downloads;sa=downfile&id=477
short video two: http://www.overunity.com/index.php?action=downloads;sa=view;down=478
plengo
Quote from: Artist_Guy on July 05, 2011, 06:10:30 PM
See such circa 8:41, cap tilt, or broken cap exists. Same video. Other video might have a perfectly aligned cap, because it was taken at a different point in time. The motor is also in a different position in that first one.
Anyway, no wires should be visible going into any hole, yet they are. Nobody has explained that. If the red wire continued onward, but -not- into the hole, it would be seen in the very view you posted.  :(
Look at my short videos and please, stop that non-sense. There are no cables going to that cap. It is just a trick of 3D video into 2 dimensions. I hate to say this, but those that are NOT EXPERIMENTING are quick to judge and think those videos proof anything good or bad. One should really go to the detail of those frames and study it first before condemning someone of being a liar or fake.
More I study those videos more I see how real it is. Experimentation has, slowly but surely, demonstrated lots to learn here besides proving that this machine IS NOT AN EASY Bedini SSG motor that you can put in 15 minutes and charge batteries (no pun intended to Mr. Bedini - great respect for him).
This motor is a beast to say the least. I am very impressed how Romero was able to build this thing with a clear vision in mind to accomplish his goals and succeed.
If you don't believe me?!! just try it yourself. Be prepared to spend some good money, time, brain power and frustration and if God bless you may be you will see the interesting things that machine can teach us.
For me that cap thingy is closed. Any more arguments about it without conclusive proof will be simply deleted. I spent easily on this pictures and short videos about 8 hours of my day!
Fausto.
nul-points
Quote from: plengo on July 05, 2011, 10:32:52 PM
Fausto.
i agree with Fausto
i also spent some time comparing different sections of the videos, all showing that same area of cables, and it was clear to me that the cables involved are just connecting the lower coil of one generator pair to its top coil and connecting the lower coil of one motor pair to its driver board & top coil
thanks for your good work, Fausto!
np
http://docsfreelunch.blogspot.com
