Muller Dynamo
0 Members and 131 Guests are viewing this topic.
marcx41
Oscar, I send to you a email, give a confirmation if you receive it, marc
marcx41
you have a new email
Scorch
5/1/13
Just finished some more assembly work on the Q2.
I have been waiting for a while because the kit was supposed to include 24 paper spacers, for the magnet retainer cups, but there was an error in the specifications and it was shipped with only 8 paper spacers. And after multiple inquiries to company to find out when the paper spacers may arrive; there has been no response to this particular question.
So I decided to use thin, #10, rubber bands which work well as they do fill gaps where needed and spread out where not needed. And I even used the same rubber bands inside the magnet retainers to keep magnets from rattling around.
And, with regards to assembling rotors like these, there are a few assembly tips to consider-
-Make sure shaft fits, easily, through polycarbonate holes.
May have to sand this area otherwise a rotor, that is too tight on the shaft, is going to difficult to work with and adjust during final assembly.
-Assemble hub so that set screws 'point' between magnets.
Otherwise you will always be fighting magnets with ferrous hex wrenches.
-Assemble hubs with shaft in place, to ensure proper alignment of all four shaft holes, in rotor halves and hubs, before tightening bolts and screws.
And, oh yeah, the bolt holes in the hubs were not tapped all the way through and had to finish all those with my own tap.  The manufacturer is aware of this but I never saw any 'follow-up' email regarding this issue. So I hope other builders are not forcing the bolts, and chewing up hubs, possibly resulting in seized parts. . .
That is all for now with regards to this build.
Still need to install all the pigtail wiring on the stator plates.
And still haven't ordered the terminal strip or extra diodes needed to actually finish this thing as it is in the pictures.
Constructive criticisms-
-I am of the opinion all the extra flat washers, and lock washers, are not necessary when using steel cap screws which tend to 'lock' in place anyway when used on aluminum hubs. I did not use all these extra washers and would actually prefer to just install 8 bolts, of correct length, versus just four bolts and all the extra washers including flat washers that 'hang' over the edges of the hubs.
-I am also of the opinion I can do without the feet kit (and lack of holes to mount the feet) and would prefer other parts to actually be included such as the diodes and alternator terminal block needed to finish as pictured.
-I also wish I didn't have to go on a scavenger hunt to locate a spray can top and construct the switching commutator. I think this critical, precision, part of a commutator should already be fabricated and ready to use.
-Not sure why all the parts, including 24 magnet holders, and 24 paper shims, are needed to mount magnets in rotors. Seems, to me, that magnet openings could simply be machined into thicker, polycarbonate, disks and save on all this complication. Sometimes simpler IS better.
-Should be a better way to mount capacitors. Hot melt glue just didn't work well for me.
-Instructions mention: 'If no oscilloscope is available to locate sine wave peak, use an analog volt meter on coil output to detect general location of positive & negative peaks when SSR's light and adjust accordingly'.
But, if I DO have a scope, there is no suggestions, in the instructions, where the test points might be for alternator, and relay, signals nor is there any oscilloscope screen shot to indicate what 'optimum' signal might look like.  In other words, there is a BIG assumption everybody attempting to build the kit will know what to connect to and look for on their scope.
-There is no mention of rotor alignment with respect to motor rotor versus alternator rotor. Should the magnets all be aligned or offset from each other? These are very powerful magnets with very larger fields. So is there any specific concerns regarding these alignments?
Thestone
Well I found that after mounting all my coils and magnets for the motor part, did not worked... I was assuming that all the coils where wound in the same way, but found 3 of the coils wound with opposite force field, I had to turn the coils around to see if this will fix this, other wise, I will have to unwound each coil and make sure is wound the correct way. The only think I dont understand if you pay so much money for this kit, there is not instructions of any kind of how to assemble the coils with respect to magnets... and no support.
I think it will be better to machine cut the parts your self and go from there, will be much shipper and faster... I had to wait two months for the kid, there is no support, no one answer your questions, etc... just follow Scorth posting and you will get something similar or better.  >:(
Thestone
Well after so many problems, I sold my kit as it is, in eBay for 1/2 the price... I will stick with Bedini Stuff. >:( this shit does not works.
http://youtu.be/FenTcWVAtyA
Conclusion : no support, not good documentation, no schematics, Lenz law everywhere, and no torque... hahaha what a waste of money....
