Muller Dynamo
Tudi
Let me try to ilustrate visually how important it is to state a magnet pull is stronger then push :
Uploaded with ImageShack.us
This "power difference" is actually an over unity quantity( Each time a magnet passes by a coil). At 1000 Hz that is a considerable amount no matter how small it might be. Let's suppowe it is 0.001 wats OU, which is small enough to be beleavable. at 1000HZ the device produces 1 watt excess energy per second ? This perfectly explains also why device speeds up under heavier load.
I'm probably wrong, but the magnet on top of the coil unbalances the push / pull ratio ? Event at that huge range it is ?
albert
I wonder why it should not be possible to run the generator part as a simple Bedini motor? You got litz coils, perhaps the neos work well with the ferrite core and a larger gap, and its efficient, too. Of course the emphasis here would be on the driving power and not so much on the energy recovery aspect of the Bedini.
A switch even if its a Hall switch is always kinda cumbersome and will it last in this kind of application?
e2matrix
Quote from: TommeyLReed on May 24, 2011, 01:59:58 PM
This is my pulse generator, that works even better the the muller wheel
Would you care to add some part specs to you diagram and give us an idea why this is better than the Muller type motor here?  Are you saying your circuit is overunity?  I'm all for solid state OU but I haven't seen it and would welcome any real info that can lead to that.
Quote from: scratchrobot on May 24, 2011, 12:27:19 PM
With magnets and small 12v 4w bulb as load on two coils.
http://youtu.be/zF7d2cBevBg
I don't have cores in all coils and my rotor wobbles so there is no balance.
Well done.
I wonder why Romero's unit did not slow down when he lifted his stator magnet?
Maybe your stator magnets are too near to the cores?
You have about 6 WATTs of input power.
How much power does your lamp put out?
Regards, Stefan.
bourne
Quote from: TommeyLReed on May 24, 2011, 04:04:13 PM
Not OU, just like the muller motor.
I show everything unlike the muller motor showing what you want to see. I would have to say that none of you are that bright when you can't even see though this simple scam.
I would just like to call all of you out that thinks he or she thinks they know better them common sense, your ego is off the charts and someone like my self needs to put you all in your place.
You all just show how you waste time and money to try to push this scam, we'll wake up it's a scam and it won't work!
Prove me wrong, PLEASE!
...sigh.
simple is it? please explain.
...in my place.....
muhahahha
Chill out man!
Here, watch All this http://youtu.be/oaMTSOI1Zk4
Click 720hd - Full screen - sit back and enjoy what Man can do when he wants to have fun.
we are all having fun, shout all you want, it's funny !!
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
