New Choke Configuration. HV Water Dissassociation. (Low Power)
Started by Dogs, January 02, 2008, 05:51:01 AM
Dogs
Hi All,
I just want to get this data out there...
I seem to have found a new choke configuration that seems to truly increase HHO production.
This configuration places the chokes, truly in parallel with the Water Cap.
The pulse does not go through the chokes, but hits the ends of the chokes on the positive and common side respectively.
The circuit resonates and produces a high voltage Lawton style waveform across the cell.
Primed or Unprimed Tubes, does not matter. Excellent HHO production.
Check out my project history at the following link:
http://waterfuelcell.org/phpBB2/viewforum.php?f=66&sid=d3c43387164791e6ab8eb7179786487c
If you have a working cell some chokes.
Try creating this setup and let me know if you have similar results.
You may have to scan around to find resonance.
When you get near resonance, the tubes will sing. Then get'em to a loud and high pitch, and you should have it.
Checkout the attached pdf.
What a great new year!
-Dogs
oystla
Very interesting. So your setup becomes effectivly an LCL resonant circuit...
But how come you don't destroy the lawton circuit with such high voltages at resonance ?
oystla
And your diode surely can't hold levels of 14 000 Volts in reverse, so why don't it break down ?
Meyer had a diode that could hold max 1200 Volts in revers, so he aimed for voltages up to max this level as far as I understand.
hansvonlieven
G'day Dogs and all,
Thank you for publishing the pdf file. good work!
What is of special interest to me is your choke design. In my research I have come across the same idea in a 1913 patent of a free energy device. Meyer, the inventor, uses four of these and arranges them as a bridge rectifier. He calls that part of the circuit his "intensifyer"
I have been trying to find out what that arrangement precisely does but no-one so far has been able to help.
Have a look at this:
Meyer did not have diodes, he used mercury vapour rectifiers instead.
For a more detailed description of the device see:
http://www.overunity.com/index.php/topic,3500.435.html   Post 436
Any ideas regarding that particular coil arrangement would be welcome, I am on unknown territory here.
My apologies for posting "off the thread" as it were but I do feel that this choke arrangement of yours has further implications.
Greetings from Australia
Hans von Lieven
Dogs
oystla,
mmmm... Questions you have... Such is the nature of resonance and OverUnity.  8)
At resonance HV increases as Amps decrease.
Maybe that's why. It works.
Diodes are not really rated under such conditions.
(This diode can handle n Volts at x Amps w/in a resonant circuit...)
Maybe, atoms behave differently under resonant conditions.
I don't know just yet.
-Dogs
