Working Magnetic Motor on you tube??
Started by Craigy, January 04, 2008, 04:11:39 PM
Omnibus
@CLaNZeR,
Thanks for the video. I see your rotor being 199g is lighter than @alsetalonkin's 258g. Could you try turning it first by hand? I wonder if these 1000rpm were imparted by hand or not? Recall, when @alsetalonkin turns it by hand the spin is at ~400rpm. As the things are going here I'll be starting these experiments on Monday, hopefully. Have the magnets already, the bearings will probably arrive today bu the parts won't be ready till Monday.
Craigy
I didn?t like al?s reply to sean about the materials, on the steorn forum.. was it me or was he being patronising?
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
Bruce_TPU
Quote from: CLaNZeR on January 12, 2008, 09:36:59 AM
Started doing some weighing and wind down tests with NO stator magnets.
The little 3mm RC bearings top and bottom give a good 4 minute wind down from 1000RPM with Rotor Magnets.
Find Video below:
http://www.overunity.org.uk/ocpm/tests/1000RPMCLaNZeRSRotor1.wmv
BTW I span it upto 4000 RPM without magnet just now and it started too lift off the table at 2500 RPM, so Blue Tacked the feet down and they are only just staying there at 4000 RPM, so be warned LOL  ;D ;D ;D
Span it up with Air Line as below.
Off to find a bit of timber too screw then base plate too and add the extra weight !
Cheers
Sean.
@ Sean
The rotor has only reached speeds below 2K.  The faster the stator magnets spin, the slower the rotor.  Where Al ran two of the stator magnets anti-gear wise, where they both sped up over 12,000 rpm's, the rotor was 1000 rpm.  So I don't think that you need worry about lift off, just yet!  LOL
Good work!!
Bruce
CLaNZeR
Quote from: Craigy on January 12, 2008, 10:05:43 AM
Well he never answered the question did he  ;D I said I had ordered some HDPE as he had recommended on another thread with the answer coming back as :
Nylon is about like congealed asphalt as far as machinability goes. It is usually molded to shape.
The Delrin (or Acetal in the civilized world) is what I used for the early rotors and all the stator bearing/magnet holders, and the 3.5 mm to 1/2 in shaft adapter. It is by far the nicest plastic to machine. It has a sensual quality about it that is somewhat indescribable. Why, when I first met Delrin...but that's another story.
Oh, and the mechanical properties are nice too.
So maybe I should or ordered some Actel hehehe  ;D
Rosphere
@btentzer,
Hey, what are you doing over here kicking it with the magnet motor guys?  >:(
Get back and finish your TPU before it gets cold!  :D
