Working Magnetic Motor on you tube??
Started by Craigy, January 04, 2008, 04:11:39 PM
Omnibus
Thanks, @Yadaraf, I'll be following your efforts closely because reproducing the Lego motor is even more important than @alsetalokin's. They are based on the same principles (as all magnet motors are) but as a concrete performance of the construction the Lego is better. As a matter of fact, if don't learn more from @alsetalokin about the weight of the rotor, the rotor and stator magnetic induction profiles and a few other things, reproducing the Lego won't be much different from reproducing @alsetalokin's motor in terms of an absent constructor.
Omnibus
Quote from: JFK on January 30, 2008, 11:11:04 PM
OK, I can agree to disagree on the Lego motor.  ;)
I do believe Al's design has a serious chance though.
No matter what agreements or disagreements we might have at this point one thing is clear, if no independent party succeeds in replicating these motors, they will stay illegitimate as any other magnetic motor in history. Constructors with such claims as the Lego and the present one somehow don't understand that it's in their best interest to be cooperative and even to go out of their way to help others to reproduce the effects they claim.
JFK
dean_mcgowan
@ replicators
Look up the meaning of he word "conned".
He is not the messiah, he's just a very naughty boy !!!
Let it go guys !!!
Nice work all the same, but at some point you really have to take a long hard look at the facts.
Cheers,
Dean
Bruce_TPU
Have we yet had a one hundred percent accurate replication, including weights, magnet separation etc.  I think not.
Give up?  HA!  I don't think so!!
What we need is more replicators, and a few more facts.  Everyone be patient.  Let's take baby steps in the right direction and we will get it.
Some are so quick to quit and so quick to declare things a hoax, one has to wonder why?  What is their motive?  I think that some on this board just take pleasure in it.
We will not be dissuaded until we have proven the device to ourselves, one way or another.  I am looking to make my unit work.  Period.
All of you naysayers, need not torture yourself with our foolish work.  So please go and haunt another board or thread.   ;)
And that is my honest opinion.
Cheers,
Bruce
