Gravity Motors = Free Energy
Started by Michel, July 16, 2005, 12:45:50 PM
Tink
Hello HartiBerlin,
Did the lower arm have enough torque to shiftturn the upper
arm under water ?
Yes it had more then enough power, it even went some 30 to 45 degrees past the top dead center and then stopped and went back to top dead center (with the wooden block inside to keep leadweight in place)
Then did the lead mass fall down again and push the air
down and create another big air container under water to get
a new torque arm for raising again ?
That was a problem!
This device needs a lock and release system because the leadweight will shift when arm is past horizontal position.
It may sound strange but weight is only pushing aircontainer down when in vertical position, and after some 20 degrees it will go to the middle again a bit.
So to answer your first question;
Did it work, when you tried it ?
Yes and no.
Yes, I proved (to myself anyway) that there is more power coming of it then to keep the device going.
No, because I haven't taken the time to make a lock and release system for the leadweight to fall at the right positions.
Do I think this device can work with a well functioning lock and release device build in?
Yep I think so.
To get a few KiloWatts you will need a huge machine and you will have your wear on parts :(
I am no longer building these machines.
Solidstate OU is what I am looking for now.
Synergy is the key to free energy.
hartiberlin
Hmm Tink,
this is very interesting !
The lock and release mechanism could be done
by a special doubble position pulse relay which needs
only a short pulse on enable and disable again the locks.
Another question is, if the air container up force was strong enough to
keep the lead weight in the upper position still at 9 to 12 o?clock ?
As the lock must only release it at 12 o?clock , the 45 degrees rotation
through 9 to 12 o?clock is the hardest part for the up-force, as the lead weight
has to be lifted in this phase...
hartiberlin
P.S: Hmm, maybe one could do this with Helium or Hydrogen in normal air ?
Okay, the forces wouldn?t be this big as under water,
but to prove the concept a small model would be okay...!
Tink
Mmm, is possible but I like a mechanical solution better because it is under water and may get wet.
And you also have to bring wires into the closed system and that makes it more complicated I think.
Yep true, the part from 9 to 12 o'clock is the hard part but,...it gained so much speed from 6 to 9 o'clock it will be no problem.
Don't forget the weight is allmost in the middle and has hardly any effect.
Air as medium (with helium inside) might not work I think unless it is big enough.
From my experience I would say water as medium is best.
Tink
If people want to build this device, here are some tips.
Don't make it too small because little errors are hard to correct.
Don't make it too big because it will cost you more material,...and make sure the thing fits in the bucket/bathtub you want to test it in. (make sure it is all underwater)
Use easy to work with rubber, the thinner the better like condomrubber or surgeons handgloves.
Don't make the leadblock too heavy,..just heavy enough it will push the "cilinder" open.
Make sure the shape of the leadblock (weight) is so that a part will allways be past the axis so that that part plays no drag role (that is part of the trick of this device I think)
Make sure your wife loves you enough for you being in your workshed all the time, buy her flowers!
Multiply the time you think you need to build it in by at least 4 times,...8 times might be more realistic.
And then your biggest problem; you still have to invent the lock and release device!
Good luck ;D
