Gravity Motors = Free Energy
Started by Michel, July 16, 2005, 12:45:50 PM
Tink
 ;D
Yep it is just one of the steps in building the toy from scratch.
There are so many shapes of floats possible and it is a little hard to calculate the weight needed for this thing, that I came up with this simple way of doing it.
Once the weight is know, you can put the weight on the scales and it tells you how many grams of lead are needed.
When you know that, it is simple to calculate what the volume of lead you have and you can start drawing the shape you like most.
A rectangular shape is best and keep in mind that the lead block should allways have a big part on the other side of the axis so that a great part of the weight cancels the (gravity) drag effect.
So when the shape of the weight is drawn on paper and you think it is good, then it is time to look for pieces of triplex or multiplex wood for the moldingbox.
I remember putting some candlewax in it and made the whole inside of the box fatty by melting the candlewax with a hairdryer.
Then I measured the lead I would need and put it in an old soupspoon and let it melt on a stove.
It is a smelly job poring the molten lead into the mold because the candlewax starts blowing smoke but the leadblock when cooled down will have smooth sides then,...just make sure you have all windows open or do it outside.
When you have the leadblock ready then it is time to start looking for a nice round or other shaped plastic box (pvc is my favorit because it goes well with superglue) where you have enough room for the shifting leadblock.
And then comes the hard part which I have not done yet, the lock and release device!
When the mechanism works on paper then it is a question of glueing the bits and pieces to gether and make the second float just like the first one.
Then comes the bearing bit and luckily I found and old axis with a connectionplate from an old experiment so that should not be that hard.
And then when all is done and it doesn't work as I thought it would,....I made a fool out of myself.
So I hope for the best.
Synergy is the key to free energy.
Michel
Who understood the operation of the machine??
