Water battery
Started by nightlife, January 13, 2008, 02:00:59 AM
nightlife
I just checked the 9volt battery and it now has 4.7 volts. That is almost double what it had before I started charging it with the water cell I created. The cell voltage was 4.7volts too but it immediately starting climbing back up when I disconnected the battery and I will check it again in a couple of minutes. The battery dropped to 3.87 after I disconnected it from the cell but it still has more then 30% more voltage then when I started.
nightlife
I put a 12vdc 2400 watt load on the cell and the voltage dropped to 1.13volts rather quickly but stopped dropping fast once it hit the 1.13volt mark. That tells me the water cell contains amperage.
I am guessing that if a multiply the cell by 12, I should get a usable 12volt power supply. That would mean I need 180 cups in a series to achieve that goal provided my thoughts are correct.
First I am going to experiment with some higher amounts of water as well as some larger pieces of metal to see if I get a higher level of voltage with the same load I introduced before.
jeanna
OK
One of the interesting things that makes me know the earth cell isn't producing its effect from only galvanic reaction is that it works (less to be sure) with the same metal.  Cu to Cu gives me 0.05vdc.
What do you get if the 2 metals are the same?
BTW there is nothing wrong with galvanic reaction. It is an irritation to have to clean off the gunked up metal every day or so. You may get more juice from lemon juice or vinegar but it will gunk up faster.
It is wonderfully empowering to be able to make a battery in cups with water. If the grid goes down it will be good to know this.  There are so many ions and metals in tap water these days. Depending on where you live the rain has ionized stuff in it too. Acid rain is water with ions in it; otherwise it would be neutral.
Let us know,
jeanna
I don't even know how to test for frequency. maybe the ac?
jeanna
Quote from: hansvonlieven on January 13, 2008, 02:05:53 AM
put a bit of vinegar or lemon juice in the water and it will work better, it also will work better in beer.
Hans von Lieven
But Hans, It would RUIN the beer!
;D
jeanna
ian middleton
Good call jeanna,
I for one don't want to be accused of alcohol abuse  LOL  ;D
