Reverse Current depending on tpu hemispheric location
Started by sparks, January 21, 2008, 04:06:21 PM
sparks
     I believe SM's tpu is collecting em potential fields by production of an electrical vortex field.  The tpu field is accelerated when a collected potential field gives up it's energy (adds photons) to the vortex electrical field.  This results in the tpu "overunity".  I am starting to believe that the scource of the collected em potentials are Earth propogated.  The tpu initiates an electrical field hurricane fed by em potential energy fields.  This vortex construct seems to be dependent on which hemisphere we find the tpu in.  Below is my theory on this construct change.
       I believe there is or was a fusion process that gives or gave rise to the Earth.  The Sun's fusion process gives rise to a hemispherical counter-rotation of the Sun's surface.  This is also seen in the gas giant planets.  I believe this hemispherical counter-rotation takes place inside the Earth's liquid/plasmic core. (tectonic plate mover?)  This rotation is driven by two electrical vortices whose axie lie between the poles and the center of the Earth..  One vortice clockwise the other counterclockwise. EM potential radiated from the sun as long wave high energy fields feed these vorti at pulsed intervals.  The rotational speed of these vorti therefore oscillate.  This oscillation of a vortex electrical field is felt all the way and beyond the surface of the Earth. The oscillation of the vortex field speed results in emwaves radiating from the core of the Earth in a direction of propogation determined by the vortex rotation. When these waves meet the tpu they are converted back to a rotational field whose spin direction is dictated by the Earth oscillating field.    Maybe? ???
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
turbo
Quote from: sparks on January 21, 2008, 04:06:21 PM
     I believe   I am starting to believe   seems to be
       I believe   I believe        Maybe? ???
you believe a lot....
can you show us something?
M.
sparks
   @Marco
Looking for theories to explain the tpu's "overunity" that's all.  Did SM tell us
definitively.  Perhaps his theory is posted somewhere on this site and I missed it.
   @all
  After thinking and studying a bit more another theory came to mind about the electrical vortex inside the Earth.  If this is not a contra-rotating vortex but just a plain old vortex then the electrical field following this spin would have it's greatest linear velocity at the equator.     Greatest change in voltage at the equator and least at the poles.  This results in a longitudinal electrical potential in opposite directions depending on which hemisphere you find yourself in.  This potential pulsating at whatever frequency the ev spin change is.
Think Legacy
Spread the Love
EMdevices
The simple fact that the first TPU changes its output with ORIENTATION indicates it's an antenna, which have radiation paterns, and if rotated the wrong way lose the signal.
SM also says in the first video that he is TUNING into the EARTH MAGNET FIELD which has an INHERENT FREQUENCY.
So these observations and statements overwelmingly indicate a type of antenna.
HOWEVER,
In later videos this apparent orientation problem seems to be fixed and the TPU can be rotated without any problem.Ã,  What's odd is the fact that the TPU looks the same, so how can he fix the orientation problem of an antenna, WHEN IT LOOKS THE SAME?
Perhaps, it is NOT an "antenna" afterall, but more like a free energy device which receives energy from somewhere (like an antenna but different).Ã,  Perhaps it gets its energy from MAGNETS.Ã,   SM did say there was so much energy in magnets and they went through so many of them in their experiments.
So if we can extract energy from the earth magnetic field, we certainly can extract energy from a magnet.Ã,  But HOW?
Is this device using principles related to SPINTRONICS, where the STATIC magnetic field sets the LARMOR precession frequency?Ã,  Ã,  Is this the 'INHERENT FREQUENCY" SM mentions?
I've been on the NMR bandwagon last year, do I need to get on that again?Ã,   Not sure at this point, but it's something to consider of course.
You see,Ã,   with NMR, or Nuclear Magnetic Resonance,Ã,  we match some of the clues:
1)Ã,  Inherent frequency
2)Ã,  Tunning is required
3)Ã,  Direction relative to the static magnetic field matters
4)Ã,  Orientation problem can be fixed easily (create another magnetic field)
and so on.Ã,
Just some thoughts to ponder.
EM
sparks
  The magnetic lines of the near magnetic field of the Earth and the magnetic lines of the Magnetosphere are indications of a vortex current inside the core of the Earth.  The vary existence of Earth dependent on this current.  Without the ionosphere being trapped by the magnetosphere we would all be screwed.  (I understand the good old usa has got some project going to punch a hole in the magnetosphere and see what happens.  Like Telsa didn't figure out a way to do this already and decided it was way too dangerous)   If this vortex is being driven by a pulsed energy scource then it's speed oscillation would result in electrical field changes strongest at the equator and weakest at the poles. This results in an electrical gradiant with it's highest potential at the equator.  So as an orbital field moves perpendicular to this  potential gradiant (parallel to the equator) due to the spin of the Earth, it sees more potentital energy on the equator side of the circle than on the pole side.  This gives rise to preferential spin. Now which way does my toilet vortex go?
Think Legacy
Spread the Love
