Identification of the Tempic field Node lengths
Started by libra_spirit, January 21, 2008, 09:37:38 PM
libra_spirit
Latest experiments:
As a sensitive of energy, I am sharing my findings as to the tempic field grid.
They are interactions of both light velocity, as well as fractal division process for photons.
If you are not a sensitive yourself skip to the lower section where the link to EM may be intuitively grasped.
http://magnetism.fateback.com/LightTech.htm
I know that scientists will often tune out and drop off after the first statements of the "Light" or an intelligent force presence within energy itself. All I can say is the sensitivity leads to being able to feel and locate the nodes, and I have tried to accuratly identify the lengths, for incorporation into other EM devices for experiment.
There is a tempic field matrix within matter operating between a system of specific length, and this grid is fractal in nature by divisions of 8.
Thus there are specific distances where the TPU loops may couple through another process not covered by EM technology at present, as well pyramid designs that may also have these qualities.
This is manipulation and coupling of the torsion fields found naturally in nature, as well as the basic design of the light as a scalar cancelling EM photon of radiant light, is broken down to become an EM field on the shells of the electrons and proton layers.
Thanks,
Dave L
spacetrax
Thank you for sharing this. Have you been able to transform that light energy into an usable form of energy here on Earth?
Quote from: libra_spirit on January 21, 2008, 09:37:38 PM
Latest experiments:
Thanks,
Dave L
libra_spirit
spacetrax,
No! LOL! Thanks for asking Spacetrax.
I did find a claim, that one of the configurations produces superconductive conductors. This is from Slim Spurlings work. I devised a way to generate high node counts in all the fractals, like Slims cubit. 20.6". And then using his method, you make two of them, palm them and then reverse one against the other. Its supposed to be superconductive, which is quite a claim in itself.
Here is my latest on the 1111 configuration, which is a high energy vibration system.
http://magnetism.50webs.com/111.htm
And the latest on the Matrix resonant lengths.
http://magnetism.fateback.com/Matrix.htm
Lots of resonant lengths to play with, some have gone into Joe Cells now.
The 925 Hz length shows promise, it generates .3 volts in water, and I believe it couples into the ionashpere.
http://magnetism.fateback.com/925hz.htm
Lastly been applying some of this science of vibrations to hemispheres on spheres.
http://magnetism.50webs.com/ElectricField.htm
And calculating the earths platonic resonances vibration rates.
http://magnetism.50webs.com/Earth.htm
We can certainly get things to vibrate, but converting to usable EM is still not aparent.
Dave L
amigo
Hi libra_spirit,
When you say "As a sensitive of energy..." what do you refer to?
Are you a "sensitive" in the terms of Reichenbach's nomenclature? Do you see the Odic force, Auras around objects and subtle fields around crystals and magnets, or do you sense (some) of them in another way or none of the above (something else)?
libra_spirit
Good question Amigo,
We are all sensitive to vibration at some level of frequency. Set your hand on a running car and feel what I would call a mass vibration effect. With devices that vibrate the nucleus of the atoms of say bismuth, which is a very heavy atom, using a function generator powered through a scalar wound coil on the bismuth core, I discovered I could easilly begin to sense vibrations up into even the 20 Mhz ranges. I have recieved similiar reports from a few others trying this also.
Since the main mass of the atoms is located mainly at the nucleus, it is floating in a magnetic field, or a diamagnetic field since it is suspended at the center of the field. The mass is free to vibrate as it spins.
I also discovered that cutting a wire to specific lengths can set up this internal vibration inside the wire, and I can feel it. There are specific lengths of copper and iron tie wire that will begin to vibrate inside and never stop as long as the length is maintained. They seem to be powering off the background matrix of the enviornment and we have been recording lengths and what we feel they are tapping energy from. Some lengths were found using calculations of say the distance from earth to moon, as if gravity is a wave. Others were discovered in other ways, but all confirmed though touch.
The vibrations were first sensed using touch, then from palming at a few inches, but later I started to be able to feel them inside the brain at the center without the direct touch.
After I got good at feeling these vibrations, I started to realize there was a fractal based system of nodes on these lengths, and one can cut them off on two nodes. The shorter segment lengths will now start to vibrate at a higher octave of the same base fractal system and this seems to be how energy is transferred between the very small and the very large.
So if you have a design you want to try these lengths with I can easily provide a length to the nearset 100th of an inch or so, along almost any range of lengths you want, to see how mass vibrations may effect your electronic projects.
Better yet try cutting a few of them and see if you can sense this vibration effect also.
Mass vibrational resonance was noted in some of the EM OU experiments circulating the net.
I am not aware of anyone else as of yet recording actual lengths where the source of the vibration may be the earths platonic vibration, or the upper ionasphere, with the exception of Slim Spurling. His work was not pointed at powering devices however.
Thanks,
Dave L
