My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
Super God
Why yes I did!  I've been following that forum very closely.  However, we already have all information we need!  This engine is going to take some work to get running.  I need to make a starter mount and get a starter, alternator, and a battery, oh and a radiator.  So it's not going to be running RIGHT NOW, but it will run soon enough!  If it won't run I'll have to rebuild it, but at least then I can make sure it's like new.  Pictures soon, once I get the camera on the cellphone working!  =D
>9000
Super God
The best I could come up with was a crappy camera phone, here you go:
>9000
Super God
My engine is one step closer to being ready for testing.  I have an alternator and starter.  Now, i need to wait until better weather to snag the fuel pump and radiator (and bell housing) from my grandpa's truck to get this thing running.  Before I order the DirectHits, I want to stick to what s1r did, I'm going to get some diodes and an inverter and attempt to wire it up like he did.  Now the only problem I have is how to connect everything,  how am I going to hook a 120v wire up to a spark plug?  What should I use for connectors??
>9000
Davetech
"how am I going to hook a 120v wire up to a spark plug?  What should I use for connectors??"
That should not be a problem. Regular spark plug wires have an insulated covering that pretty well keeps in 20kv or 30kv of electrical pressure (voltage) from a standard spark coil so I think they would work just dandy for 120v.
HotRod82
Out of all the things I've read this one actually looks the most promising. After reading up on this for some time I realized that this has not been tried on a fuel injected motor. If that were possible I would be more than willing to try it on my 94 VW jetta. I plan on doing an engine swap in the future anyway. What are your thoughts on combining this system with an HHO generator? Any thoughts? Advice?
