My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
tishatang
@Cap70
Thanks for you reply
tishatang
Unicron
With Choke you reduse the air going to the engine, so it get's more gass. (water)
So the little thing (carb nozzle) with 82 on it should probably be bigger.
i see you got out the whole nozzle but for the 82 one the nozzle can be seperated form the tube its on.
so if you get an other one do not be surprised to get only this
it think the second tube with 6 or 9 on in is the idle nozzle, i do not know if you can get a bigger one for that?
and srew in the air screw so it gets less air.
xbox hacker
Great work Cap70...i cant wait till your next video!
BTW... what design of yours are you running in the video? Is it the one with the SCR's or a older one??
gotoluc
Quote from: Super God on July 02, 2008, 12:04:00 PM
I don't know why luc created the other thread.  We have gotten excellent results with capacitor70's circuit.  User jcbx6 over in the waterfuel1978 group has gotten his volvo to run on water with the same circuit capcitor70 is using.  So over here we are making progress rapidly.  The postal service is slower than molasses so I still have to wait before I can get mine working too.
By the way, I don't think this system uses THAT much electricity that it would drain a battery.  You would need two, however, because the starter motor drags down the voltage so much it would put the inverter in self protect mode.
Looking good so far, full steam ahead.
Hi Sg, I created the other thread because I found that water explosion could be achieved without a large capacitive discharge and that seems to be very interesting and worth looking at just that. Also please note that S1R has said his system does not use capacitors. So, in order to not create confusion in this thread since you are using a different approach I started a new topic. At this time my updated circuit (on page one) of the topic I started uses only 1uf or 2uf depending on the inverter output.
Are you sure user jcbx6 at the waterfuel1978 group is saying his Volvo is working on water at this time?
@capacitor70 my congratulations :D to you in demonstrating that it is truly possible to get a ICE to run on water ;)
Keep up this important research :) we will find the way to get this done one way or another.
Luc
pablitosax
Good Job Capacitor70 !!  ;D
Viewing your video i'm  thinked that wou engine needs more fuel (water)...remember , s1r9a9m9 said : "
ussing carburettor jets two sizes larger than normal".
And another probe that you can do is retard the ignition timming 35? degrees.
Amazing job ...really !!!!
