My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
capacitor70
Its not only my work, SuperGod, 22vision, resonanceman, Shanti guided me how to do it, I just followed steps...
mrock
WOW !!!
Real Fire Works for the 4th of July!
Awesome work!
ALL YOU GUYS AND GALS ROCK !!!
IT WONT' BE LONG NOW !
lots of hard work but it will pay off.
Congraduations to everyone and cap70.
thanks,
mrock
bigger jets, switch mode ps - hz up
livingwaters08
Quote from: capacitor70 on July 04, 2008, 06:47:10 AM
Is that small motor on your video a two-cycle motor?  It kind of sounds like it is.  If so, are you using soluble oil to lube the bearings?
It is four stroke 100CC two wheeler engine.
Were you able to adjust the timing of the magneto or are you using an external  automotive type ignition?
ignition timings are not modified.
I have an electric start two-cycle engine, but i am wondering about rust and lube to the bearings in the crankcase.  And, also how to adjust the timing in a simple way with an magneto.  Of course, I realize each brand of motor is unique.
Two sroke engine is not sutable for plasma system, water stays at bottom of piston.
These are some photos of carburator.
Which part of carburator is needed to modify to get it continuously running ?
I am not mechnical engineer please explain in detail, dont confuse me...
When I give choke it starts, without choke it dosent work at all....
Capacitor70,
In the 2nd image on this page.  The jets need to be enlarged.  You may be able to find larger jets which would simply replace these which are in place.  These jets supply the amount of fuel to the venturi which meters the spray of fuel into the cobustion chamber.  Hope this helps.  If you can gain acccess to a schematic of the carburetor, you will see which jets lead to.  Here you will be able to adjust the jets for idle, run, and high speed, by enlarging the hole size, orifice of these jets.
GOOD LUCK!
HHHONOW
capacitor70
Please explain me with reference to Jet diagram from above images, I am not mechnical engineer, I need to make big holes to all these three jets ???
Circuit used in working model.
DO NOT FORGET BULBS
Unicron
@cap70
no not make bigger holes yourself, buy them, if you try to drill yourself you can break them or mess up the flow. or make them to big so you will flood your cylinder.
i replyd to your pm
