My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
xbox hacker
Quote from: Park34 on July 20, 2008, 02:27:28 PM
xbox hacker
so the
8x6kv 470PF one u linked on ebay, would you only need one capacitor then??
i see on the capacitor it says 6kv
Theoretically.....
I got mine from arcade chassis too  ;D
The ones you mentioned are 3kilavolt ...but for the capacitance...i dont know
Dread
I just sent an email to Aaron asking this (It is his circuit), but can anyone confirm the wiring is correct on this slightly modified version of his spark enhancing circuit please?
http://www.mediafire.com/?nnmjbj9mrjn
rfsimoes
Hi all,
Does any one know if there is a delay between the spark in the HV side of this latest cap70 circuit and the spark in the LV side?
Today I was finally able to run my engine again on gasoline. I found dirt in the low rpm needle...
I was able to start the engine without the circuit, with just a direct connection between the HV coil and the plug.
Then I tried to use the spark of LV side of circuit and... No fire...
After that I tried to return to directly run from HV coil, forgot about groundings and them a smell of burn silicone came to my attention :o
The TIP122 burned me and it was shorted... So tests are over for today :'(
All of this was tried without the inverter on, so no plasma was running. I want to start the engine and then plasmate it ::)
So why doesn't my engine run with normal spark from LV spark plug?
Any Ideas?
rfsimoes
resonanceman
Quote from: rfsimoes on July 20, 2008, 05:54:46 PM
Any Ideas?
I would check the polarity  ..... somethng must be backwards
plasmate
great word
I can't wait   till everyone  is using it
gary
xbox hacker
UPDATE:
I have uploaded a new video show my cap70 setup...take a look!  ;D ;D
http://www.youtube.com/watch?v=fWX31mR3vCE
I couldn't film, trigger and spray water all at the same time, so in the video is running with a small amount of water that was on it prior to filming.
It would seem that the HV polarity is not an issue with this setup. I tried it both ways.
