My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
xbox hacker
I have been working in the arcade field for awhile...so now its just a JOB...lol
You work in  a coffee shop for years...do you want to go home and have coffee?  :D
The power supply is now the trickey part to cap70's setup... I can flip the switch as fast as i can with 2 fingers ( like a paintball player shoots rapid fire) it dies not miss....BUT i can see the energy is decreassed form the first fire to the last. So we need  a faster charging system. I am unsure if Cap70 has this problem.....
As for the power supply, if you have access to a 220VAC output inverter you are set, other wise you have to use a 110VAC invert and a voltage doubler. I am useing a voltage doubler in all my videos, Cap70 also said to me that he is now using a 470uF cap...and the plasma is much better (than his 330uF)! As for the amps i cant check them, my meter only goes up to 10A...and i need it for work, so i cant take a chance on killing it.
With my doubler i have 290VDC with the inverter and 330VDC with a wall socket. I recently put a 150W lamp inline...like Cap70, just so i can see if the plasma fires when it is in the block, cuz you wont be able to see it then..LOL  ;D
Park34
Yeah i hate replacing the fuse on my fluke
so am i hearing you correct
you have a battery then a inverter to 110v then a doubler to 240v then the bridge the the capacitors and the wining and back again??
is the double just a transformer, IE windings used to double the voltage
xbox hacker
Quote from: Park34 on July 20, 2008, 08:50:41 PM
NO...the doubler acts as the bridge...A bridge is full wave rectifier...the doubler is 1/2 wave rectifier. Its not a transformer with windings...
Battery>>>doubler>>>plug
xbox hacker
UPDATE:
I was bored so i fired off the setup for about 5-8 mins non stop, AS FAST AS I COULD! The coil DID get hot. I am unsure if a coil with different size windings and number of turns,or if it were a toroidal coil, would have the same results ...these are the results of my coil ???
happyvalley808
Xbox,
Computer power supplies have a ferrite ring in them, about the size of a 50 cent piece...
HV
