Helmust Goebkes magnet motor
Started by hartiberlin, January 24, 2008, 05:18:12 AM
Joh70
Thank you, Nerz, for your effort to put in that drawing. The secret behind seperate iron or ferrite-magnets  / iron-containing-soft-magnets could be there property, to interact with inertial iron-particles. These particles are adapting to flux-changes with a delay. during these process they either absorb or add additional magnetic force thru there according electrons-spin which is overunity (a sort of quantum mechanics). Neos are not soft.
R_weng777
 I worked on a magnetic perpetual motor for about five years,and learned alot in the process, mine was based on Ezekiel wheels where both rotor and stator were moving,it  the only way to go for infinity.But i gave it up,Here's why? All energy comes from light(electro-magnetism) C= M/E; light when it strikes matter(protons, earth) produce eletron-positron pairs.Electron positron collisions produce a pair a quarks, it takes 3 quarks to make matter, combining to form planets and stars, thus creating light. The circle is complete, not closed but open infinte,Thats all well and good for PM inventors exept one thing; the higher the over-unity the more light is needed, a mini-black hole.Stealing fire from the sun, might be bad for the liver,Of course fire from heaven might be bad for the soul. It's provable, the science is out there.Solution create your own light source, to go with  your machine.Yours probably won't use to much light. Good luck.
wizkycho
Hi all !
I've seen somewhere web page with simmilar drawing
describing work of permanent magnet lifters...
can someone find original the link ?
priniciple of work is in picture
if build properly COP is easily 100 - 1000 !!!
Wiz
RunningBare
Quote from: wizkycho on January 31, 2008, 05:59:39 AM
Hi all !
Wiz
The diagram in essence is one of these...
It trades distance moved for force, unfortunately since magnetic flux degrades rapidly with distance it will never match the distance the lever has to be moved.
wizkycho
this is not a per. mag. lifter of type described in picture
this one doesn't shuts off mag. flux completely.
the one I'm talking about (principle described in picture)
completely rerouts flux so it is not existant for load and
in other moment there is full mag flux. wanting to grab something
energy to invest in rotation of magnet is thiny bit
in comparison what magnet will produce attracting heavy weight (load on rotor
) if air gap made sufficiently small.
wiz
