Helmust Goebkes magnet motor
Started by hartiberlin, January 24, 2008, 05:18:12 AM
gyulasun
Hello Wiz,
Yes, I got it now, you are right with low RPMs up to a certain RPM the pulsed input energy need can be less with respect to the others.
I wonder if you know about another forum where (among other things) Lindemann's rotary attraction motor is discussed? And there is a member there from Latvia with friend circles of laser cutting possibilities and lamination sources... it would be worth a try to write him and ask if he could help?
If you think you can freely enter that forum by registrating first (so that you could see all the great photos / drawings on different motor replications) here: http://www.energeticforum.com/  and the this is the thread I point at:
http://www.energeticforum.com/renewable-energy/271-electric-motor-secrets.html
This is quite a long thread already (started last April) and member Jetijs came there only at around Summer/Automn, you will surely find his posts and pictures, like this: http://www.energeticforum.com/renewable-energy/271-electric-motor-secrets-9.html#post11096
Good luck!
Gyula
wizkycho
Quote from: R_weng777 on January 30, 2008, 11:34:52 AM
I worked on a magnetic perpetual motor for about five years,and learned alot in the process, mine was based on Ezekiel wheels where both rotor and stator were moving,it  the only way to go for infinity.But i gave it up,Here's why? All energy comes from light(electro-magnetism) C= M/E; light when it strikes matter(protons, earth) produce eletron-positron pairs.Electron positron collisions produce a pair a quarks, it takes 3 quarks to make matter, combining to form planets and stars, thus creating light. The circle is complete, not closed but open infinte,Thats all well and good for PM inventors exept one thing; the higher the over-unity the more light is needed, a mini-black hole.Stealing fire from the sun, might be bad for the liver,Of course fire from heaven might be bad for the soul. It's provable, the science is out there.Solution create your own light source, to go with  your machine.Yours probably won't use to much light. Good luck.
Koje Laprdanje (Elephant Shit) !
Try and put some Cu wire in the sun and meassure voltage at the end - you 'll get nothing
Try better with coil - nothing again (you'll say because it is Pair of electron-positron so voltage is 0)
Lats have total absence of Sun and fire, lets have 0 K (-273 C)  and still at this absolute zero you get current and magnetism that moves for free
and can make work - free energy. So where is the sun now. You have situation of total darkness but if energy is utilised - comming towards sun.
Your theory says that if you surrond OU device in a box of outvards mirrors that OU device will stop functioning ????
Your theory says that if I draw black circle on paper (scince black doesn't reflect light I must have created many many el-pos pairs and they can not escape this circle...) I have actually created a black whole ??? am I powerfull or what ???
Your theory says that all the cows with black shapes are potential danger of creating black whole. What about dalmatian dog's black spots all over
cccc.
So don't spread this old lady witch booga-boo thories - cause they are totaly apsurd.
Wiz
Low-Q
What about just put a sheet of alu-foil in two different locations. Connect a cu wire from each of them. Then you will measure voltage from the two other ends. There is allways electrical potential differences in two different locations, so you have a capacitor charged by the environment :) Cool?
OK. When it comes to magnetism, magnetism is only one element of at least two required to produce energy. So magnets alone will never produce energy out of free air. However there is many interesting approaches to OU, and I can never let the thoughts about a working magnet motor or SMOT let go.
Vidar
Scorpile
Using a little coil betwen the stator plates wouldn't regauge the stator magnets?
ignilc
i am close to a freely rotating magnet arrangement.. i hope so.  :)
