Chas Campbell video: The fault.
Started by longtong3, January 28, 2008, 11:40:05 AM
longtong3
http://peswiki.com/index.php/Directory:Chas_Campbell_Generator
On this links, looking at "Video Still Shots" pictures right below the Ten News / YouTube; 4th June 2007. I notice something and ask, just to confirm I see it right.
Just call the wheel at far right # 1, next to its left is wheel # 2, then wheel # 3, then red flywheel and the generator. The input motor right under whell # 2.
1- Wheel # 1 blue color, is double wheel, mounting on base by 2 bearings & a pulley,
this pulley cover by big O ring or something, and it rotate by touching (not pulling)  wheel # 2 right pulley. Am I right?. And why this wheel is double & what is purpose of it? ( Why is it double & what the wheel does in the system )
2- Wheel # 2 , green/yellow collor, mounting on base by 2 bearings, left big pulley is pulled by input motor via V-belt. The smaller right pulley rotate the # 1 wheel by touching its pulley and pull the # 3 wheel by V-belt & belt adjuster ( can see belt & belt tention right on front )
3- Wheel # 3 green/yellow color, offcourse is pulling by wheel # 2. Does wheel # 3 pull the flywheel? NO, I DON'T THINK SO.
4- The center of red color flywheel is at about 2/3 of wheel # 3, it couldn't connect directly to wheel # 3 by shaft or by gear. WHICH TURN THE FLYWHEEL so its left pulley can pull the generator & produce power? Am I right?
Pls correct me if I am wrong.
