Thane Heins Perepiteia.
polarbreeze
Quote from: Mr.Entropy on April 02, 2008, 12:51:04 PM
Quote from: polarbreeze on April 02, 2008, 07:31:08 AM
I think I would. I have in mind, for example, the two curves in figure 12 (page 9) of this paper: AC Induction Motor Fundamentals
Remember that the shorted coil has to act like a brake.Ã,  Comparing the two load curves on page 9 in that paper, you can see that the unstable load requires less torque than the stable load at some speeds.Ã,  This is inconsistent with the application of a brake.
I wonder then if the motor's torque-speed curve actually has a positive slope, not a negative one, at this point. It seems likely because the motor is running at only about 20% of its rated speed. That doesn't necessarily explain it either, I realize, but see also my post 1457: I'd be interested in your thoughts around that.
PB
polarbreeze
Quote from: OilBarren on April 03, 2008, 07:13:03 AM
Quote from: polarbreeze on April 03, 2008, 06:59:50 AM
The more fundamental question is whether pushing the system into instability, however you do it, can actually result in any power gain because as I said before this has to be about power, not about speed.PB
WHERE'S MICHAEL FARADAY(Faraday's Law of Induction re: deltaT) WHEN YOU NEED HIM?
Thane
ps oh look...here he is:
http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/farlaw.html
Power, Thane. Not voltage. Power. Mr Faraday is supportive, as is Mr. Lenz.
PB
OilBarren
Quote from: polarbreeze on April 03, 2008, 07:19:41 AM
Thane
Power, Thane. Not voltage. Power. Mr Faraday is supportive.
PB
POWER = V^2/R
THE FASTER THE GENERATOR TURNS THE MORE POWER IT PRODUCES - deltaT gets smaller.
THE FASTER THE INDUCTION MOTOR TURNS THE LESS POWER IT CONSUMES
SO INFACT IT IS ALL ABOUT SPEED.
Thane
polarbreeze
...and the more mechanical power is required to drive it.
PB
Not if you're also asking it to deliver more mechanical power to the generator.
PB
vibrovirii
Hi Thane and others, I would like to thank you for all this information and effort   :D
I'm half way through reading the pages and making lots of notes.
Going to play around with this after i'm done reading this topic.
Peace, V
