Thane Heins Perepiteia.
0 Members and 36 Guests are viewing this topic.
CRANKYpants
Quote from: adjust on July 26, 2008, 05:33:49 AM
Hi Adam
you can find all patent pages and updates about Thans Heins at my hubpage
http://hubpages.com/hub/The-full-patent-blueprint--Perepiteia-motor
You can rightclick and download the full new patent page by page,
or mail me at
Info.adjust@gmail.com and I will send you the pdf
I try to put the pages in a video at you tube but the file was too big. :'(
But i upload a video at youtube with a direct ling to the page with the new patent photos ::)
the name of the video is:   NEW 2008 !!! PEREPITEIA MOTOR THE FULL PATENT BLUEPRINTS
Thanks for your support
Adjust
DEAR ADJUST,
YOU HAVE A TYPO - HOLY GRAY - SHOULD READ HOLY GRAIL.
ALSO THOSE PATENTS ARE NOW PRETTY MUCH OUT OF DATE.
YOU OUGHT TO UPDATE YOUR INFO WITH OUR NEW COIL DESIGN AND LINKS TO THE MAY AND JUNE GENERATOR VIDEOS AT OTTAWA UNIVERSITY.
ONE FINAL THING - I WOULD SUGGEST YOU CALL IT THE "PEREPITEIA GENERATOR" SINCE THAT IS WHAT I CONSIDER IT TO BE BUT OF COURSE IT IS UP TO YOU.
CHEERS
Thane
JustMe
alan
Have you also tried pulsed DC?
Maybe it gives a clearer result if a known quantity of current is put in the device, for instance:
Capacitor -> charge pump -> opamp sine generator -> sine voltage
Just a thought, keep up the good work.
CRANKYpants
Quote from: alan on July 26, 2008, 10:47:09 AM
I AM NOT SURE HOW MUCH CLEARER YOU WANT IT?
WHEN I DOUBLE CHECKED THE METER LOAD CURRENT WITH THE SAME METER (BECAUSE I COULD NOT BELIVE WHAT I WAS SEEING) - THE METER SHOWED 0.086 A AND THE CALCULATED LOAD CURRENT IS:
Ir = 8.57 / 100.5
Ir = 85.3 mA
GOTOLUC HAS BEEN USING THIS METER FOR QUITE A WHILE AND I AM SURE HE CAN VOUCH FOR ITS ACCURACY.
NEVERTHELESS ALL THIS MUST BE VETTED BY THE UNIVERSITY SO IT MAY ALL BE IN ERROR - WE WILL SEE?
I AM TAKING A LITTLE VACATION UNTIL THEN.
(PLEASE FORGIVE MY "SPOOK-O-METER" BUT SUGGESTING THAT THERE IS AN UN-"known quantity of current" IS A TYPICAL SPOOKISH TACTIC OF CREATING DOUBT WHERE NO DOUBT EXISTS AS IS SUGGESTING ALTERNATE CONVOLUTED TESTS TO MAKE THINGS "CLEAR" WHEN A SIMPLE APPLICATION OF OHMS LAW WILL SUFFICE).
CHEERS
Thane
gyulasun
Quote from: CRANKYpants on July 26, 2008, 11:06:13 AM
Ir = 8.57 / 100.5
Ir = 8.53 mA
HI Thane,
Sorry to draw your attention to a typo but 8.57 / 100.5 = 0.0853 A  and it is 85.3mA,  not 8.53mA,  right?  This nicely corresponds to your measured 0.086A (which is 86mA).
Thanks,  Gyula
