Thane Heins Perepiteia.
CRANKYpants
QuoteThat is great news son, I am proud of you!
SO FAR IT'S GOOD NEWS. BTW THANKS FOR YOUR... "Fascinating, direct question"PREVIOSLY.
QuoteSo I would root for the concentric bi coil, this would seem to have the most potential (no pun)
Ron
STRANGE THAT YOU MISSED THE (PUN x 2) OPPORTUNITY TO MENTION "POTHANETIAL"?
YOU ARE SLIPPING MASTER I_B_RON COQUITLAM.
T
CRANKYpants
Quote from: Kator01 on October 07, 2008, 05:29:33 PM
Hello CRANKYpants,
I understand from your video-presentations that the HV-Coil is shorted for the accellerating effect. How can it be that a shorted coil has selfresonance-behaviour ?
Kator
YOU HAVE A HV COIL WITH A VERY HIGH IMPEDANCE - SO VIRTUALLY NO CURRENT FLOWS - WHEN A ROTOR MAGNET APPROACHES IT,
IT STORES ITS ENERGY IN THE ELECTROSTATIC FIELD LIKE A CAPACITOR.
WHEN THE ROTOR MAGNET IS TOP DEAD CENTRE TO THE COIL - NEITHER APPROACHING NOR RECEDING - THE SHORTED "CAPACITOR" HV COIL DISCHARGES THROUGH THE COIL'S RESISTANCE AND CREATES A MAGNETIC FIELD (RESONANCE) - WHICH BY THIS TIME IS DELAYED AND IT PUSHES AWAY ON THE NOW RECEDING MAGNET AND SIMULTANEOUSLY ATTRACTS THE APPROACHING ONE.
FOR THE HV COIL TO WORK THE INDUCTANCE HAS TO BE RIGHT, COIL IMPEDANCE/RESISTANCE HAS TO BE RIGHT AND ROTOR FREQUENCY HAS TO BE RIGHT,
AND THE POLITICAL ACTORS McCAIN AND HARPER MUST NOT BE ELECTED OR WE ARE ALL SCREWED - HUMAN BEING AND NATURE EXPLOITING CORPORATIONS AND WARMONGERS WIN.
CHEERS
Thane
alan
Hello again Thane,
what happens when you put more of these coil blocks around the rotor?
- Does the currentdraw stay the same or increases?
- How does it accelerate/decelerate compared to 1 block?
- Does the overall efficiecy increase or decrease? (if it increases, can it be increased to OU??)
Just some thoughts, hope I make sense.
Kator01
Hi Thane,
thank you for explaning ths. Now I know what you mean by resonance. The max flux-change must not  pass unnoticed by the coil.  You talk here about the current-voltage-phaseshift.
Yes, I think we are already screwed - even here in Europe.
Some good info here :
http://www.tbrnews.org/
Go to the archive and read TBR News October 3, 2008
Also interesting the curriculum vitae of the person ( Neel Kashkari ) entrusted with controlling the distrubution ot the bail-out-money :
http://www.whatdoesitmean.com/ - topic : "Top Area 51 Stargate commander..."
Both he and H.Paulson are former Goldman & Sachs Managers.
Look here :
http://www.treas.gov/organization/bios/kashkari-e.html
Now we know whom we are dealing with and where the "vanished"  money went.
Kator
Kator01
Hi Thane,
I think testing the basic  behaviour of the HV-Coil would be necessary
I would like to setup a solid-state test-rig - that is - a pulsing hc-coil  opposing an hv-coil - both in fixed position.  In this way I have better possibillities in altering the key-parameters like puls-frequency, puls-.duration, di/dt etc and watch at the same time the reaction of the hv-coil via an hall-sensor or the voltage-drop over a very low resistor ( 0.2 to 1 ohm ) embedded in series in the shorted coil.
Can you give me an hint, what core-material of the hv-coil is suited best ? I could imagine we are working here in the range of 20 to 15 KHz so a flyback-core-type would do it ?
And what material for the hc-coil which is sitting on the outside area of hv-coil ?
Thank you for all this hard work Thane. I wish you all the best.
Kator
