Thane Heins Perepiteia.
CRANKYpants
COPY of private post to Thane...
Danke für die Abbildugen!
I was being a smart ass and went to a 11 X 18 mm laminated core... but only 55mm long....
It came out at 60 some ohms and .9 H
IF FIRST YOU DON'T SUCCEED - GO BACK AND FOLLOW THE INSTRUCTIONS.
YOU NEED VOLTAGE BABY!
MY HV COIL PRODUCES 240 VOLTS @ 1100 RPM AND REALLY TAKES OFF WHEN ENGAGED.
QuoteBut no acceleration at any speed... so got pissed off and went back to me HBG (hildenbrand/Genesis)
So interesting to see your new core and readings!
(pic 1)
(pic 2)
QuoteThe bit of black plastic is to keep them apart as there are no clamps...
What is your PCD on your rotor?  How many magnets? (I know, you have said...)
I AM STUNNED - PCD?
18 MAGNETS
QuoteTake care Ron
Note: I had made this core before I had seen Mr T's...but I see my resistance is only half  and same
with the henries...duh also this is the same rotor that didn't work the very first tests I did... could
the pot magnets have something to do with this.
THAT'S LIKE MY WIFE ASKING ME,  "DOES THIS DRESS MAKES ME LOOK FAT?" "NO YOUR FAT ASS MAKES YOU LOOK FAT!"
SO NO THE POT MAGNETS HAVE NOTHING TO DO WITH IT IT IS YOUR LOW VOLTAGE/STORED CAPACITIVE ENERGY AND POSSIBLY YOUR LOW FREQUENCY.
IN MY TESTS A 87 OHM COIL AS ABOVE DOES NOT PRODUCE ACCELERATION - BUT A 124 OHN ON E DOES NICELY.
CHEERIOS
T
i_ron
Quote from: CRANKYpants on November 08, 2008, 06:39:45 PM
snip
I AM STUNNED - PCD?
18 MAGNETS.
snip
CHEERIOS
T
Stunned?  I guess so... I am too...Here I thought I was talking to an educated, intelligent, mechanical engineer..."PCD"  stands for...PITCH CIRCLE DIAMETER. So if you were to measure from the center of one magnet across the rotor to the center of the opposite side magnet, that would be the PCD, in other words, the diameter of the circle you laid out the magnets on....
K, now we are even, lol, I will try for an 88 ohm coil then, hehehe
Ron
i_ron
Quote from: i_ron on November 08, 2008, 06:59:06 PM
Ron
OK, to be very serious for a moment... a warm feeling of belonging came over me as I admired Mr T's
grand pictures... in particular the one below showing the Robertson head screw!
Many non canucks viewing this photo might miss this proud canadian moment so I will reference it for you... you can insult our beer or our prime minister.... but boy, never insult our screws!!!
Canadians make the best screws!
http://www.mysteriesofcanada.com/Ontario/robertson_screws.htm
Ron, last of the canucks
CRANKYpants
CRANKYpants
