Thane Heins Perepiteia.
woopy
fantastic :)
and i stay always very interested to get some coils and rotor in Europe
do you intend to market some demo proto to show your work overseas?
bravo and go on
Laurent
wattsup
Quote from: CRANKYpants on February 25, 2009, 07:37:37 PM
OK, THE MOTOR AND GENERATOR ARE BOTH 100% EFFICIENT AND ALL THE ELECTRICAL POWER IS CONVERTED INTO MECHANICAL POWER IN THE DRIVE SHAFT AND THEN ELECTRICAL POWER IN THE GENERATOR (WE USE MAGNETIC BEARINGS IN A VACUUM).
WITHOUT THE HV COILS ENGAGED THE MOTOR CONSUMES 0.003 WATTS TO PRODUCE 0.003 WATTS, EFFICIENCY = 100%
WITH THE HV COILS ENGAGED THE SYSTEM ACCELERATES AND THE FIXED MOTOR INPUT = 0.003 WATTS (ACTUALLY IT IS GENERALLY ABOUT 50% LESS WITH HV ACCELERATION BUT FORGET THAT PART) AND THE GENERATOR OUTPUT = 21 WATTS.
21/0.003 x 100 = EFFICIENCY 700,000%
CHEERS
T
Please, please tell me I have not read what I just read. What are you talking about man. Does not make any sense. The drive motor is definitely not running on .003 or .0003 watts with or without the HV/HC or whatever. Come on already. And nothing is 100% efficient. So I don't get it at all. Sorry. Something is wrong here when it could be sooooooooooooo simple.
First thing you need to do is change the batteries in your voltage and amp meters to make sure your instruments are not giving you erroneous data. @CP this is serious shit and your attitude of taking it so lightly is puzzling. If that motor was consuming only .0003 watts, you should be able to run it with a 1.5 volt battery. I just don't get it. After 429 pages, I am as numskulled as ever. 700,000% efficient.... WHAT????
Power in versus  power out is what counts. Geez, forget about torque on shaft and all this other talk. Just measure all the input power. One going to the drive motor and any other coil used to drive the rotor, add up this energy in watts, then measure what the generator is producing. Can't be any simpler then that. Then you should come back and report the results as follows.
INPUT at ________ rpm
Drive Motor: Volts ____ Amps _______
HV Coil: Volts ____ Amps _______
OUTPUT at same rpm with a suitable load
Generator Coil: Volts ____ Amps _______
If what you are saying is seemingly true, then you should be able to get rid of the drive motor and just put the shaft on a vice and start turning the rotor manually to 25 rpm then engage the HV coil to make it run and you should still have tremendous overunity.
LarryC
Do they call Thane the Old Pot Stirrer, because he was the Chef in his restaurant or does he just enjoy dropping a bomb and watching the objects flail about ???
LarryC
Times up!
Thane and I_Ron on a recent trip enjoying there two favorite hobbies ;D
i_ron
Quote from: CRANKYpants on February 25, 2009, 07:55:34 PM
WELL OF COURSE I WANTED TO BE CONSERVATIVE AND NOT RUFFLE ANY FEATHERS...  :-[
NO KIDDING A 10 LB ROTOR ACCELERATING UP TO 3500 RPM FROM 25 RPM WITHOUT ANY ADDITIONAL POWER TO THE MOTOR - WHILE DELIVERING POWER TO A LOAD AT THE SAME TIME - BOTH - GOING UP AND COMING DOWN.
T
Why of course we all believe you!
Ron
