Thane Heins Perepiteia.
0 Members and 23 Guests are viewing this topic.
CRANKYpants
HERE'S THE DEAL PEEPS,
I AM WORKING 12-14 HOURS PER DAY, EVERY DAY TRYING TO GET A NEW PROTOTYPE FINISHED AND I CAN'T KEEP UP WITH THE REQUESTS FOR THIS THAT AND THE OTHER THING - SORRY NO KIDDING :-[
PERHAPS PEOPLE CAN ASK blisteringanomaly SINCE HE SHOULD BE CLOSE TO BE UP AND RUNNING WITH HIS NEW STUFF?
ALSO I COULDN'T GET THE TESTS DONE TODAY EITHER - SINCE I WAS GIVING A DEMO.
SORRY AGAIN
PS
MIKE ARE YOU OR YOUR BROTHER COMING TO THE LAB SOMETIME?
CRANKYpants
Quote from: adlep on February 27, 2009, 02:57:28 PM
Greetings,
@ Thane...
Please consider conducting "my" simple experiment with the battery that I have proposed few months ago. I have no doubt that it will show real gains coming out of your setup and it should quiet the PB types for a while but without disturbing your work schedule.
Such an experiment will not be difficult at all to conduct.
1. Get a car battery that is fully charged.
2. Connect it to the DC or AC motor.
3. Observe a run time.
Then
4. Recharge the battery.
5. Connect it to the DC or AC motor that employs your coil setup.
6. Observe a run time.
Such a run will give you a very impressive material to show to the business executives that do not care about technical details or Electrical Engineering.
DEAR ADLEP,
YOU ARE GOING TO GET YOUR WISH - BUT NOT FROM ME.
THE PROTOTYPE I AM CURRENTLY BUILDING IS A 4 COIL UNIT WHICH WILL BE RUN UP TO FULL SPEED AND MAY OR MAY NOT GO BEYOND THE 3600 MAX SPEED RATING OF THE MOTOR - WE WILL HAVE TO WAIT AND SEE ABOUT THAT. I AM BUILDING A 1/2 INCH BULLET PROOF LEXAN CASE FOR TESTING JUST IN CASE IT WANTS TO PULL A "GOTOLUC - EXPLODING NEO SHITSTORM".
IT IS HOWEVER, INTENDED TO PRODUCE MORE POWER (ACROSS A LOAD - HOPEFULLY 40 - 50 WATTS/COIL @ 200 WATTS)
THAN WHAT THE MOTOR WILL BE CONSUMING AT CLOSE TO ZERO SLIP @ 90 WATTS OR LESS..
THEY PEOPLE WHO ARE GETTING IT WILL THEN RECTIFY THE OUTPUT, FEED IT INTO A BATTERY AND THEN RECTIFY IT AGAIN BACK TO 60 HZ AC AND TRY TO SELF RUN THE SYSTEM. THEY ALSO WANT TO USE A DC MOTOR AS WELL I THINK.
SO ALMOST EVERYBODY WILL BE SATISFIED SOON I HOPE?  ;)
CHEERS
T
LarryC
Quote from: CRANKYpants on February 27, 2009, 09:48:51 PM
DEAR ADLEP,
CHEERS
T
Outstanding T, a great effort on your part and very much looking forward to your results.
Regards, Larry
hoptoad
Quote from: hydrocontrol on February 27, 2009, 05:29:59 PM
.........Now what if you can improve that generator so it can produce 4400 watts using a 1 hp weed eater engine. You are now talking about using a lot less gasoline to produce the same amount of energy. See it does not have to be OU to be very beneficial.
Bad example hydrocontrol, because 746 watts equals 1 horsepower, so if you were able to get 4400watts from a 1 horsepower weed eater, then you would be getting 6 times more output than input, which would obviously be OU.
Cheers
LarryC
Quote from: hoptoad on February 27, 2009, 11:21:56 PM
Cheers
So Hoptoad, according to your theory, now that I purchased a 16 seer heat pump and saving over $150 on average a month over the old 10 seer unit then I must be getting OU and not an increase in efficiency ??? So please explain!
Regards, Larry
