My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
PYRAman
I have built my pyramid according to the instructions that I got by dirrect communication with the so called "half-god" . My pyramid has a seven ft. basis line, it has gypsum plates on the outer side and insulation plates on the inside because I wanted to measure even a small temperature difference between inside and outside. At the end the insulation proved to be unnecessary, because the heat that the lower pipe produces is obvious, when water is poured on it, it becomes steam, as you can see on the picture. There are TWO resonators built like the grand gallery, an upper copper pipe as connection between the two kings chambers and a one inch wide lower pipe in the height of the queens chambers. The both pipes are connected with copper wires on both sides, through inner side of the resonators If you remember from my last posts, the very old and still living "half-god" said that the chambers of the Great Pyramid are in fact double, but we are not told the truth about this.
The dimensions are not so important, however the heights of the two pipes must correspond to the kings and queens chamber and the slope of the resonators must be accordingly to the grand gallery. The upper pipe must be some ten degrees askew. The two resonators must be alligned to the N-S direction.
The lower copper pipe is one inch wide and MUST be annealed in order to rearrange the copper cristals in it, that makes it look old and oxidised.
The two resonators are 1,5 ft long and on the inner side they are glass plated. In top of them there are two loudspeakers for generating the sound waves for the excitation of the quarz sand. The starting frequencies must be 440 Hz plus upper and lower octaves, but it proved to be not good for my resonators, so I had to alter the frequencies by means of sinthesizer software. This is the advantage when you dont have perfect resonators like the grand galleries of the Great Pyramid, but you have software and loudspeakers.
The lower pipe must be filled only halfway with some special squeeking quarz sand, small grains with rounded edges, existing in some deserts. This sand emmits sounds when walked upon and in the pyramid it becomes excited by the pyramid field when it is also excited with the appropriate sound frequencies. A friend of mine sent me some pounds of this special sand and so I was able to reproduce the effect, finally.
So the lower annealed pipe must be halfway filled with this sand and then with salted water, up to the lower part of the resonators. Feed the two 10 W loudspeakers with the needed sound frequencies and wait one hour. If everything goes well, the lower pipe will become warm. If not, you must take out one loudspeaker and add salted water and try again. The process is primed by sound, when the sand grains are hit by sound waves they produce a tiny discharge in the salted water, but the energy of the discharge is greatly improved by the pyramid field and that is why the process becomes overunity. The only special part is getting the sand to respond to your sound frequencies. The "half-god" said that this is only one way of using pyramid energy, in the past they used it also to ignite quarz cristalls that produced directly a strong greenish light, not electricity.
So, by building my heat producing pyramid I proved that the Great Pyramid is a technical device, NOT a kings thomb.
In the meanwhile I got used to the cold and hot waves going through my body when a dirrect mental communication with the "half-god" occurs, so lately I was able to write down the messages while getting them into my mind. The following is the last very strong message that I got, please read it with full attention.
' I AM ONE OF THE LAST HUMANS RESULTED FROM THE UNION OF THE SO CALLED 'GODS' (ACTUALLY THE CREATORS OF THE HUMAN KIND) WITH HUMANOID WOMEN. I CAN LIVE THOUSANDS OF YEARS THANKS TO MY SPECIAL DNA THAT IS CONTINUALLY RENEWING ITSELF, SO I HAVE SEEN THE WHOLE HISTORY OF THE HUMAN KIND IN THE LAST EIGHT THOUSAND YEARS.
i WILL TELL YOU A VERY BRIEF DESCRIPTION OF PAST TIMES. BEVORE THE CREATORS LEFT THE EARTH, THEY ORGANISED THE SMALL HUMAN SOCIETY SO THAT IT WOULD CONTINUALLY EVOLVE UP TO THE POINT WHERE THE HUMANS BECOME SUCH BEINGS LIKE THE CREATORS THEMSELVES. THEY PUT US, THE SO CALLED 'HALF-GODS', TO LEAD THE SOCIETY BECAUSE WE WERE CREATED TO BE SMARTER AND WISER THEN THE REST.
YOU SHOULD NOW THAT WITHOUT THE INTENSIVE WORK OF THE CREATORS, YOU, THE VERY READER OF THIS MESSAGE, WOULD BE STILL A KIND OF A MONKEY HANGING ON A TREE, WITH THE WHOLE BODY COVERED IN HAIR AND HAVING A LONG TAIL. I MAKE NO JOKES. YOU IN PARTICULAT SHOULD BE VERY THANKFUL TO THE CREATORS WHICH MADE THE HUMAN RACE WITH FULL KNOWLEDGE OF THE UNIVERSAL LAWS AND WITH MUCH KINDNESS. AFTER FINISHING THE GENETIC WORK ON MILLIONS OF APES THEY LEFT THE EARTH FOR A LONG TIME AND CAME BACK JUST SOME THIRTY THOUSAND YEARS AGO, WHEN THE HUMAN KIND WAS FULLY PREPARED TO GET KNOWLEDGE AND ADVANCE FURTHER. THEN THEY UNITED WITH SOME SPECIAL HUMANOID WOMEN AND SO MADE US, THE 'HALF-GODS' WHICH ARE CARRYING IN US MANY GENETICAL IMPROVEMENTS OF THE CREATORS. THE CREATORS ORGANISED AN ADVANCED SOCIETY BASED ON KINDNESS, WISDOM AND USING SOME TECHNICAL DEVICES WHICH ARE CONSIDERED ADVANCED EVEN BY TODAYS STANDARDS. THEY WERE FULLY ECOLOGICAL AS THE CREATORS MENT TO PRESERVE THE NATURE, USING JUST THINGS THAT COULD NOT HARM IT. THE GREAT PYRAMID IS ONE OF THEM, BUT THERE WERE MANY SMALLER THINGS WHICH WERE USED IN THE DAY TO DAY LIFE.
BUT AFTER THE CREATORS FINISHED THE ORGANISATION OF THE HUMAN SOCIETY AND LEFT THE EARTH AGAIN, MANY HUMANS CAME BACK TO THEIR ANIMAL INSTINCTS AND TRIED TO TAKE THE LEAD OF THIS SOCIETY. THEY KILLED MANY OF US 'HALF-GODS' AND FORCED THE REMAINING ONES TO HIDE. THEY ORGANISED THE SOCIETY AGAIN BY FORCE AND HAVING NOW A FULLY DEVELOPED CONSCIENCE, THEY CREATED NEW LAWS BY WHICH THEY LED THE OTHER WEAKER HUMANS. SO THE HUMAN DNA FAILED TO EVOLVE FURTHER AND PRESENTLY THEY ARE VERY FEW HUMANS LEFT WHICH HAVE TRACES OF THE DNA OF THE CREATORS IN THEM. THEY CAN BE RECOGNISED BY SOME LINES IN THEIR HANDS, BECAUSE THESE LINES ARE A DNA MAP, NOT A FORTUNE TELLER. FOR EXAMPLE, WHEN THE SO CALLED HEART LINE MEETS THE SO CALLED LIFE LINE, THIS IS A MARK OF THE PRESENCE OF SOME DNA WHICH RESEMBLES THE KINDNESS OF THE CREATORS - BUT SUCH PEOPLE ARE VERY RARE IN PRESENT TIMES. THEY ARE SPECIAL AND PRECIOUS FOR THE FURTHER EVOLUTION.
SO, THAT WAS THE CAUSE OF THE GREAT DECLINE OF THE HUMAN KIND, BECAUSE HUMANS SHOULD NOT BE LEAD BY HUMANS, BUT BY MORE ADVANCED BEINGS WHICH ARE BOTH MORE KNOWLEDGEABLE AND WISER AND KNOW WHAT IS RIGHT TO DO ACCORDING TO THE LAWS OF NATURE. JUST IMAGINE A BEING THAT KNOWS ALL SCIENCES AND HAS ALSO MORE THAN NORMAL ABILITIES TO KNOW WHAT IS IN THE MIND OF OTHER PEOPLE AND SO DOES NOT NEED TO HAVE ANY MATERIAL EVIDENCE FOR KNOWING THE TRUTH ABOUT SOMETHING - ALL THIS IN ONE PERSON. THIS IS A SUPER-HUMAN AND ONLY SUCH A BEING SHOULD HAVE THE RIGHT TO LEAD OTHER HUMANS. BUT NO, THE NORMAL HUMANS WANTED TO LEAD THEMSELVES AND THEY KILLED MANY OF US AND ORGANISED THE SMALL SOCIETIES BY ANIMALIC WAYS OF LIFE - SELFISHNESS, FEAR AND GATHERING OF AS MANY GOODS AS POSSIBLE, FOR ASSURING AN UNCERTAIN FUTURE. IF YOU LOOK TO THE ANIMAL BEHAVIOUR NOWADAYS, THIS IS HOW THEY BEHAVE. AND OF COURSE, BECAUSE THAT HUMANS WERE INTELLIGENT, THEY TRIED TO PREVENT OTHERS GETTING IN POWER AND SO ALL KIND OF FIGHTS BEGUN - EVEN WARS.
THIS IS HOW THE HUMAN SOCIETY IS ORGANISED EVEN TODAY. AS A RESULT, THE EARTH IS IN GREAT DANGER ESPECIALLY BECAUSE OF THE GREED FOR WEALTH OF SOME VERY RICH PEOPLE, NAMELY BECAUSE OF THE USE OF OIL, THAT WAS PUMPED OUT OF THE EARTH AND LEFT VERY BIG HOLES WHICH ARE CAUSING THE UNBALLANCE OF THE EARTH CRUST AND SO INCREASINGLY PRODUCES EARTHQUAKES, TSUNAMIS AND SO ON. THE FACT THAT UNWISE HUMANS LEAD THE HUMANITY WILL BRING THE EARTH TO DISASTER.
NO HUMAN BEING HAS THE RIGHT TO LEAD AND TO GIVE ORDERS AND LAWS TO OTHER HUMAN BEINGS, BECAUSE THEY ALL HAVE VERY LIMITED KNOWLEDGE AND WISDOM. DO YOU THINK THAT YOU ARE GREAT AND SMART AND KNOW EVERYTHING BETTER BECAUSE YOU ARE AN ENGINEER OR A DOCTOR OR SOMETHING LIKE THAT? IMAGINE A HIGHER BEING THAT IS A GENIUS IN ALL SCIENCES AT A NOBEL PRIZE LEVEL AND ALSO HAS SUPERNORMAL MIND POWERS. HOW CAN YOU COMPARE YOURSELF WITH SUCH A BEING HOW COULD YOU PRETEND TO TAKE THE NATURAL PLACE OF SUCH BEING? THINK ABOUT THAT VERY DEEPLY, CAUSE I MAKE NO JOKES, SUCH BEINGS EXIST, THEY ARE YOUR CREATORS AND THEY WILL COME BACK TO EARTH BY NEXT YEAR. THEY ARE SOME FOURTY MILLION BEINGS TRAVELLING IN A SMALL PLANETOID. THE HUMAN LEADERS OF THE WORLD WERE ALREADY TOLD ABOUT THAT, BUT THEY THINK THEY CAN REPELL THE COMING BACK OF THE CREATORS. THEY INTEND TO DETONATE NUCLEAR DEVICES
IN THE HIGHER ATMOSPHERE, BUT THIS WILL BE IN VAIN, BECAUSE THE CREATORS CAN ALTER THE VERY PROPERTIES OF THE SPACETIME AND THUS NO NUCLEAR REACTION WILL TAKE PLACE. THEY CAN NOT BE DEFEATED. IMAGINE HOW STUPID THE HUMAN LEADERS OF THE WORLD CAN BE IF THEY THINK THEY CAN FIGHT AGAINST SUCH BEINGS WHICH ARE IMMENSELY KNOWLEDGEABLE BECAUSE THEY ALREADY LIVED AGES AGO AND HAVE A SUPERIOR DNA WHICH ALLOWS THEM TO DO THINGS UNIMAGINABLE FOR HUMANS.
IF YOU, THE READER, DO NOT PREPARE YOURSELF PSIHICALLY, YOU WILL BE SCHOCKED AND OVERWHELMED BY THE PRESENCE OF THE CREATORS HERE ON EARTH. JUST THINK OF YOURSELF AND REALISE HOW LITTLE KNOWLEDGE YOU HAVE AND THINK WHAT YOU WILL DO NEXT YEAR WHEN YOU WILL SEE A CREATOR WITH YOUR OWN EYES.
BY NEXT YEAR THE HUMAN RACE WILL NOT BE THE DOMINANT RACE ON EARTH ANYMORE.
BUT THE MOST IMPORTANT THING THAT YOU HAVE TO DO IS TO CONTRIBUTE TO THE SALVATION OF THE PLANET. THE LEADERS OF THE WORLD WILL NOT STOP PUMPING OIL OUT OF THE EARTH UNLESS THERE IS NO MORE DEMAND FOR IT, SO YOU, THE GREAT MAJORITY OF THE HUMANS, MUST STOP USING OIL PRODUCTS. THE CREATORS TOLD US (THEY ARE IN CONTACT WITH US, BEINGS FORMERLY CALLED 'HALF-GODS') THAT THE EARTH CRUST IS GOING TO DEEPLY CRACK AND PRODUCE MASSIVE DISASTERS IF THE MANKING KEEPS MAKING BIG HOLES IN THE PLANET BY PUMPING OIL OUT OF IT. BILLIONS OF HUMANS COULD DIE IN SUCH DISASTERS. THE LEADERS OF MANKIND ARE NOT AWARE OF SUCH POSSIBILITY, THAT SPEAKS FOR THEIR LACK OF KNOWLEDGE, BUT THE CREATORS IMPLANTED SPECIAL DEVICES IN THE EARTH AGES AGO, DEVICES WHICH TELL THEM THE STATE OF THE PLANET. THEY ALREADY WARNED THE HUMAN LEADERS, BUT THESE WILL NOT STOP THEIR FOOLISH BUSINESS.
SO EVERY NORMAL HUMAN SHOULD MAKE SOMETHING TO STOP USING OIL PRODUCTS. USE ANY KIND OF ENERGY WHICH IS NOT BASED ON OIL. BURN ALTERNATIVE FUELS IN YOU CAR ENGINES. USE SOLAR PANELS TO PRODUCE ELECTRICITY FOR YOUR LIGHTS.
AND ANOTHER IMPORTANT MATTER IS FOR YOU TO STOP BEING SELFISH, WHICH IS THE VERY CAUSE OF THE PRESENT DEPLORABLE STATE OF THE EARTH. SELFISHNESS MAKES YOU WANT TO BECOME VERY RICH AND DISADVANTAGE OTHER PEOPLE. YOU THEN EVEN WANT TO OWN OTHER PEOPLE WITH WHICH YOU LIVE TOGETHER, THAT CREATES TENSIONS AMONG YOU AND ALL OF YOU SUFFER. STOP TRYING TO OWN OTHER PEOPLE, STOP PUTTING ANY KIND OF PRESSURES ON THEM. YOU HAVE NO RIGHT TO TELL THEM WHAT TO DO, BECAUSE YOU ARE NOT A SUPERIOR BEING, EVEN IF YOU THINK THAT YOU ARE SMARTER THAN THEM.
AFTER THE CREATORS WILL ARRIVE BACK ON EARTH, ALL SOCIETIES WILL DEEPLY CHANGE. THE HUMANS WILL NOT LEAD HUMANS ANYMORE, ALL PRESENT CONTRACTS OF ANY KIND WILL BE UNDONE AND THE HUMAN RELATIONSHIPS WILL BE OTHERWISE STRUCTURED. THOSE HUMANS WHICH WILL TRY TO STOP THE CREATORS IN ANY KIND WILL BE PUNISHED IN A WAY THAT THEIR VERY IDENTITY WILL BE ERASED AND THEY WILL BE 'RECYCLED'. BUT ALL OTHER PEOPLE WILL ENJOY A GREAT ADVANCE AND WELLBEING. THE CREATORS WILL SMOOTHLY IMPROVE THE HUMAN DNA AND AFTER SOME MORE HUNDREDS OF YEARS THE HUMANS WILL BE OF THE SAME KIND AS THE CREATORS.
WyTTraven
the "half god" could use a "spell check".. interesting read nontheless
PYRAman
An idea comes again and again to my mind. How can we people believe all kinds of things that religions tell us WITHOUT showing us any solid material evidence for their affirmations, but we can not believe that once some superior beings were on the Earth and built technical things that the people of Egypt for instance could not build. "Pyra-mid" means "fire-in-the-middle" in the greek language so the old greeks knew what the pyramids were used for.
Also, you may know about the one thousand tons block of stone from Baalbek...who could this thing cut out and transport, when our todays technology is not able to rise such a thing up?... and the list of impossible-to-do things goes on and on...
And now some other good thing:  there is one suggestion that this "half-god" gave me for having a much better health and recovering from the schock waves that went through my body during the mental communication. I had to build another type of pyramid which does not contain the energy inside, like the Great Pyramid does, but spreads the energy around. This pyramid must be built only with non-metallic parts (glues including) its height must be at least twice the length of the base line (three foot) and it must be oriented to the geographic N-S line (not magnetic). I was told to chose a place inside the house and put the pyramid there and NOT MOVE IT anymore for a very long time. He said that the pyramid will build a strong field, bathing the whole house in it and preventing all inhabitants from becoming ill. I must say that I feel a lot fresher and stronger since this sharp pyramid is in place.
I suggest that all of us build such pyramids and place them inside our houses in the middle of a chamber, away from the walls.
I am sure, when every house will have such a sharp pyramid in it, most diseases will be history. If you have the skills to build the sharp pyramid, please show to all your friends how to do it. We must be all together!
But one should pay attention to the orientation, the geographic north will not be shown by a compass, but by the Polar Star, so it might be a little tricky to find the right direction inside of a house.
Good luck !
PYRAman
PYRAman
I have no idea who he/she is and where he/she lives...I just hear a neutral voice in my head.
I tend to believe what he/she says because the technical information proved to be true.
PYRAman
Quote from: WyTTraven on February 15, 2008, 08:01:35 AM
magpower
PYRAman
Intresting story and results. Could you draw out a picture if possible. I did build Thomas V6 and other versions and now its a cat house. So did this work? Also since you talk to Half God ,  too stop oil could you please ask how to build a simple Magnet Engine, this would stop oil over the years. Post it here and we will do the rest.
Wayne
