My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
guruji
Hi Drammon you should use that sand man it really makes good sound hahahahahah.
But that's not singing sound it's more grumbling sound :)
Ok ok bye bye.
nitinnun
the illuminati are extremely weak. most of their manpower and resources have left them, since 9/11/2001.
the illuminati will not be with us for much longer. they will be replaced with a wise, benevolent leadership.
i have plans to release what i know. and if whats his name doesn't complete my pyramid design, than i eventually will.
what is left of the TOOTHLESS illuminati, cannot touch me. and i laugh at the burning ruins of their backbone.
guruji
Hi guys the long pyramid is really powerful I did about four and a big one with cartoon and felt different energy.
I do meditation and am sensitive to energy guys it's true.
Nittinun let us know what you know about them as a generator please.
Thanks
nitinnun
i posted about this in the news forum. but type about it here too:
* the pyramids magnetic field moves in one direction. from peak to base.
this is current. and current can charge up a capacitor!
to make the magnetic current strong enough to be useful, you must do a few things first!
* add a copper peak is added to the pyramid.
this will increase the capacity of the positive half of the pyramids magnetic field.
the copper peak will also force more "magnetic current" to flow through the pyramid.
* never allow the copper peak, to electrically touch the ground!
if the copper peak is grounded, than all of the positive magnetic energy will drain out of it and into the ground.
* you may wrap the base of the pyramid in aluminum foil. to increase the capacity of the negative half of the pyramids magnetic field. but this is not as neccessary as the copper peak.
* stick an "antenna" inside the pyramids peak. attach it to the positive half of a capacitor.
* stick another "antenna" inside the pyramids base. attach it to the negative half of a capacitor.
you could also stick the base-antenna into the dirt. so long as the base antenna is within the negative half of the pyramids magnetic field!
* the positive magnetic current should dump into the peak-antenna.
* the negative magnetic current should suck energy out of the negative half of the capacitor.
creating a negative energy debt, inside the negative half of the capacitor (this is how a normal capacitor works).
sparks
  I don't know if this helps but the below diagram shows the relationship between the elementary geometric shape (the triangle) and segments and circles.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
