My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
spacetrax
Hi,
you are absolutely right! But, as I understood from the messages of the so called "half god" we should now save the planet, not our money... :o   If this story proves to be real, our money will be replaced by a new and special currency after the coming back of the "Creators" so the bucks will be of no use anymore.
Best,
Spacetrax
Quote from: amigo on February 27, 2008, 09:14:11 PM
I'm sorry but none of those ideas above are "free" energy. You have to eat nutrients in order to ride that bike, and if you are tired, sick or disabled, then no dice. Vegetable oil has to be processed and if it costs more energy to process it than it produces than it is not worth it.
Then again, even this pyramid heating is not cost effective (energy wise) if you had to invest energy through those 2x10W speakers, which had to be hooked up to an amp and a pre-amp, signal source, etc.
I am of a belief that there's no free (as in beer) energy out of the blue, therefore we must make a small investment of something to (hopefully) get a lot back. Because nature does not work on closed loops we are bound to get energy in a form that our current appliances/applications will not be compatible with. The goal should be two-fold: first we need to produce (negative) energy with a small investment from our side and collect, convert or use it.
If we wish to directly use it then the second part comes in, we need to design/create all new devices that will directly use the energy in the form we obtain it from the Nature, which means new light sources, new motors, etc. The task might be daunting but nothing is impossible, if there's a will there's a way.
PYRAman, if your friend could share with us a proof-of-principle electrical device as well as a light source and a motor that could satisfy those requirements above, that would be really helpful and practical at this point. Everything else is pointless if we are beating around the bush as many researchers are, without the "primer" on how to actually do it.
Just my 2c...
starcruiser
Carl
amigo
I'm really not worried about money in the equation when we speak about clean energy - money should simply not be an issue when it comes to survival of mankind versus destroying our habitat. What I'm talking about it taking the money totally out of the equation because it is one of the corrupting influences. We need a source of energy that will overthrow current system of dependency where we pay a racketeering fee to get onto the grid.
This energy source has to be clean and simple yet impossible to block or put a meter on and charge for it. Therefore we need a primer from whoever is willing to help us at this stage, because as it seems we are to dumb, to ignorant or to disconnected from the Nature to figure it out on our own. :)
spacetrax
Hi@all,
I finished my russian type pyramid, I made a 7 ft. high piece and after some hours of pondering  I decided to spend at least 15 minutes inside to see how it feels.
Well, against all expectations, it worked in some way. I remained in the pyramid longer, seated on the ground nearly half an hour, and after some time I felt a great pressure on my forehead, like when the blood pressure rises very much. And after getting out of the pyramid I was very, very tired, I think it was too much!
So, it works and the effects are quite obvious. I attach a picture. The material was wooden plates made of pressed wooden chunks, commonly used in construction works.
Best,
Spacetrax
mungibung
hi ,
I'm not privy of the Russian pyramids, but it looks dimension wise a little different than the GPG dimensions, Probably  it's the camera angle. I don't ever remember getting a headache after sitting or sleeping under one. did you have a headache to begin with? I like the back ground in the pic, reminds me of the calif, foothills
                                                   michael ;)
