Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
wings
here the tesla magnetic spar gap (switch)
Marzio
gotoluc
Thanks wings for your replies and information,
Huum :'( ...too bad Tesla isn't here to explain the difference with what he did with magnets in the spark gap compared to what I'm doing.
Luc
hartiberlin
Hi Luc,
you are diverting the spark away from the other electrode it wants to reach,
so you switch off the spark much faster.
This is also what Tesla already invented and so he could have a much better and higher
induction BackEMF voltage from his coils.
The same you are doing now.
The spark is just bend away from your  copper wire and magnet, so the
current goes out much faster and thus you have more charge up
induction voltage inyour cap.
Yes, try with a droplet of water between it and
then also try with just a graphite rod from a pencil
versus the magnet.
Please let us know, what will work best with your setup.
Many thanks.
P.S. What will happen,if you use the other side of the transformer ?
How fast will this coil charge up the cap ?
Probably even faster, right ?
slapper
Thanks for the reply gotoluc.
Quote from: gotoluc on February 17, 2008, 12:27:13 AM
slapper Q: Is there a way for you to check the magnets before and after, maybe even during. I am curious if their strength changes?
A; I will try that later and get back with the results.
slapper Q: I am wondering if you have any different results if you flip your magnet stack and coin assembly upside down and strike the coin at the top with the magnets on the bottom.
A: I tried that and I get the best effect by pulsing the top of the magnet.
I got out my crude version of Gray's conversion tube and stuck a magnetic at the end.
I will be testing to see what difference there is with the magnet running a spark through it. No positive results
to share. I think I will replace the steel rod with a copper one. I will get into this in detail some other time and
share results later. I do not want to distract you from Thane's work.
Steven Mark got some of his tpu's going using a magnet in a similar fashion. It might help solve a piece of the
tpu puzzle.
Thanks again and take care.
nap
we are not alone :)
wings
Stefan
h20 + carbon + sparck = Nanotubes and fullerenes
Nanotubes = elecron cluster = high  temperature superconductor
Is this the way?
But you add another effect to the actual one.
Step by step.
Marzio
