Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
gotoluc
Quote from: poynt99 on June 21, 2008, 12:37:23 AM
excellent work and findings Luc ;)
do you think you might be able to rig it up in a fixture so it runs by itself without you holding the wire/carbon rod?
Hi poynt99 and thanks for looking.
Yes I do think I'll come up with some kind of contraption ;) ,...also I found that the coper wire works very well on this setup also. Seems like a high resistance air core cuts down the plasma that burns the magnet and wire.
Stay tuned for updates.
Luc
gotoluc
Quote from: libra_spirit on June 22, 2008, 03:15:02 PM
Aether22,
My set up is exactly like Luc's diagram only I replaced the transformer with an automotive coil and this is a three wire circuit. So if you run a wire between the input winding and output winding for a shared common ground you have it.
Using a large paper clip out of the top of the coil I can now experiment with HV arcs also. The magnet on the input side alters them radically extending the reach and strength of the HV arc.
Dave L
Excellent work Dave ;D, this is exactly what I'm hoping everyone will do. Test it and put in your version, ideals and then share your results. The more do this the sooner we can find a great use for this effect. Who knows this could be part of what we are all looking for.
Please test and share.
Luc
gotoluc
Hi all,
here is a video I made of the ideal Dave (user: libra-spirit) had of pulsing an ignition coil (instead of a transformer) by using the neo magnet circuit I posted. Also note that in the video I am using only 12 volts DC from a battery.
Enjoy and play safe if you try this: http://www.youtube.com/watch?v=t_3OkDvmp_Y
Thanks for sharing Dave.
Luc
poynt99
nice demo Luc
when you tried shorting directly to the alligator lead (bypassing the magnet), there was no spark produced?
nightlife
 Hi gotoluc, I watched your last video and I was wondering if that concept would be a good way for splitting hydrogen from water? I think it would make for a good experiment.
