Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
Koen1
Ah, ok, thanks for explaining. :D
Now I get it. :)
xee
@ aether22,
Koen1 may understand what you are doing, but I don't. Is this what you are doing? If so it is impressive that you can get a spark using such a simple generator. But youmust drain the batter real quick. Is the wire being moved parallel with the face of the magnetic pole or is it being moved towards and away from the face of the magnet pole?
aether22
That would be impressive, but no.
To make that drawing about right cut the wire that comes from the + battery terminal where it passes over the magnet, and make and break that connection quickly above the magnet pole.
The making and breaking pulses are not sharp enough if it's not over the magnet pole, but with placement over the magnet the magnet bends the arc blowing it out quickly. (it is the breaking that forms the spark naturally)
xee
hydrocontrol
Quote from: aether22 on June 26, 2008, 06:53:14 PM
So what it appears to be now is a standard magneto which is used in a lot of small cheap engines to generate a spark.
http://science.howstuffworks.com/question375.htm
