Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
synchro1
The Hans Coler thread on Energetic Forum has revealed the Neo magnet as a super conductor. These 1/16 Neo cylinders connected serially would deliver power as negative Ohms in direct proportion to the distance from beginning to end:
synchro1
                                             Negative Ohms
For any given magnet strength material;
The negative resistance is directly proportional to the distance between the electrodes.
synchro1
Here is the streamlined converter. This long magnet conductor can shuttle an amplified back spike.
synchro1
Here's a very simple flyback generator that improves Hans Coler's loose connection approach by enclosing the spark in a vacuum tube and permitting frequency control:
https://www.youtube.com/watch?v=1U5lXqkoMzE
The current is polarized and accelerates toward the attracting pole inside the field of the magnet conductor. The output is a function of the acceleration time and distance of the current inside the nested power field of the magnet conductor. The current will increase velocity toward infinite voltage with sufficient distance.
There appears to be a "Radiant attribute" of the flyback current that interfaces with the magnet field that does not accompany ordinary current.
norman6538
Gotoluc, I recently was working on permanent mag power by stacking and unstacking to get additional power and realized that Kunnel and Figuera were probably do that very same thing.
Kunnel powered his entire house but was not connected to the grid. And when asked did it work he said "yes but not as drawn".
I'm finishing up my permanent mag power by stacking and unstacking and if inadequate will turn to coils and permanent mags because you can control them better.
I used the Lafonte attract/repel balancing but found that magnetic spin made the attraction
stronger than the repel. I have compensated for that by distance but have not measured the results yet.
Norman
