Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
konduct
Omnibus You are a true delusional ... maybe we are all crazy since we try to break the laws of physics... but you my boy are so far from reality its depressing...whatever makes you feel better buddy...the only thing I think you're onto is giving me a headache from trying to make logical sense of your ramblings...you're going to make me subconsciously voodoo you if you keep it up... I smell computer problems...maybe a blown power supply or something in your near future...remember...the universe will always balance itself, no matter how many smot ramps you have around.
mscoffman
sm0ky2;
Force is power. The time integration of power is energy. So the time integration of
force is energy.
"and you are leading people to believe that the integral of a force, that decreases with distance, remains constant with distance?"
In a vacuum, Yes, This statement, independent of it's context, is absolutely true. You need
to use the area under the curve surface integral that you often see in magnetics equations . The mathematical integral symbol with the circle through it. In means, the integral but over the surface area of a volume. Learned in college physics. It's mathematical calculus adapted to Mag. fields.
...The incremental Radius squared decrease of field strength is due to the fact that the same energy that was operating over one spherical surface at time t is same one operating spread over a larger spherical one at time t+(distance/C) the distance a wave front propagates in time t where
the wave is moving at C the speed of light. The wave front which is moving at the speed of light
due to conservation of energy (a vacuum doesn't absorb it) reaches the larger spherical surface
with the same *total* energy, the receptive interval X has just been mapped divided by R^2. What else??? Where else did that energy go? That is why when you transmit energy it is gone from the local process, you transmitted it. The same power bill is received by a radio/TV station independent of viewership.
There is no power in a circular tomi-track arrangement. It is just like a generator
or alternator with a shorted output coil...it acts as a brake. Think of shrinking a
tomi track down to six inches and forcing the rotor to rotate. It turns out that as
soon as you take a linear mag track and bend it you create a definite interval
over which the surface integral operates. It's the bending that does it and a
circle is a perfect bend. So the circle is most inefficient for unit length.
The x-machine;
So it would be more efficient to be mostly linear and when you do curve it to
do it as rapidly as possible, so that the mag forces can't integrate over time.
Remnance forces need to drive through a wheel radius. Remnance forces
act as a receptor phase delay.  It is often claimed that magnets discharge
in overunity devices, which I don't buy. Nope, remnance is most probably
destroyed. So, I think that this is going to work...Long enough to convince
someone to do the material's research to extend lifetime of the remnance
in small steel spheres. ;D
Believe what other people observe, just don't believe their theories.
It's not a race but we are racing Mib's. They are probably changing
the material makeup of kid's toys, even as we speak. I propose we
build it out of wood to put the Mib's into the tree growing business.
How's that for a phase delay?
Mark
sm0ky2
i dont think OMNI should be banned for disagreeing. It's really not his fault, he was trained to examine things this way. Im an engineer so i look at everything from a different perspective.
He's trying to look at the inside of the device when we dont have all the information.
while im putting the device in a box and looking at the input/output.
i think im done arguing over this, its obvious that he just doesnt get it and/or isnt willing to perform the experiments for himself to verify that his solution does not fit the problem.
If hes not intentionally trying to misinform people then i fear he may never figure out why the square peg doesnt fit in the round hole.
Tinker
Gwhy
You Get it
With the rotation clockwise i have lined up my neos in a sawtooth looking thing. Two neo's and connected with 3 balls in total its about 15 inches long each side.
The wheel is 18 inches cus that is what they had at Home Depot no science here.
I used the waste from cutting my wheel to mount my neos in an arc on the left side of the wheel to conform to the contour of the wheel.
The sticky end terminates and lays flat under the wheel at the other end of the neos about 5 inches beyond the center point of the wheel.
You did good with your graphic you may want to update it.
I did some Redneck testing before I ran my keyboard and it seemed to play out, but I am still building, the check is still in the mail.
Clazner I am stuck on Verticle right now, you are doing a hybred whip mag I can't get my head around that right now but you do GREAT WORK, THANKS.
Be well folks
Tinker
Omnibus
@smOky2,
Don?t continue with this because you?re sinking even deeper in confusion than I originally thought you might.
To not waste time with this I?ll just point out that what I told you concerns the magnetic potential only, not the combination of magnetic and gravitational potential as you?ve misunderstood.
You need to come to terms with respect to some basic physics notions to avoid compromising your proof. We don?t need someone claiming violation of CoE laughed off at that level.
