Where can we get a computer to adjust timing/fuel mixture
Started by bubblemonkey2, February 23, 2008, 01:07:00 AM
bubblemonkey2
is there a company that actually makes and sells (seperately from their kits) a module that can adjust enging electronic ignition TIMING as well as fuel mixture on our computer controlled cars?  That one company will NOT sell the "HFACE Optimizer" seperately. (I asked)
This is so that we can take advantage of TDC (top dead center) explosion in our piston chambers as Roy Mcallister suggests is key to engine performance and extending MPG.
I know there are several fuel leaning tools like that O2 sensor extender out there, and also that engine lean LED controller (out of stock until JUNE?)  but none of those deal with the critical issue of TIMING...Is there one that could adjust TIMING as well as the others avaiable now?   Or I would even be happy with a module that could advance or RETARD timing on its own, as I know the other lean tools exist
If so please post a link..
And IF not, anyone know if can we RETARD the timing MANUALLY on our engines enough via Mechanic's to adjust the piston location for the faster leaner burning HHO gas we are inserting into the air intakes to achieve TDC explosion?
triffid
I am visiting my brother in May who can answer your question.He is an auto mechanic and installed a hho unit on his truck.I am sure he knows the answer to your question.I will try to get him to post a reply here.Also I'm sure that that there are auto repair books on your car that will tell you how.If you don't want to wait till May.triffid
triffid
I found a link that might be useful to you.http:www.pelicanparts.com/techarticles/914timing/914_timing.htm
hope this helps you.triffid
