pulse motor and schmitt switch problems
Started by jasonspinmaster, February 28, 2008, 07:16:06 AM
jasonspinmaster
i need some help on a pulse motor circuit .
i am using a OPB 876 optic sensor, which is connected to a 555 timer as a  schmitt switch, so that i can source up to 200ma. ???  and in turn control the speed of the disk.
supply is 12 volts
col resistance is 10 ohms.
i have placed a 1k resistor for base to emttier, which in not in  the picture.
the idea is that i am using 1.5mm nail to pass through the optic sensor, which in turn firing the coil when the light in BLOCKED, i am firing on to  six magnets (6 nails) making it more accurate than a reed switch when  firing.
my problem is i know i have to place reistors  in to circuit but i am not to sure where or how to do it and i can not find any thing on the net.
gezgin
You can look Ossie Callanan's circuit with reed switch
from "A Working Radiant Free Energy System.doc"
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
jasonspinmaster
Quote from: gezgin on March 01, 2008, 03:53:24 AM
I know how to connect up i reed switch.
but i do not need a reed switch circuit.
gezgin
jasonspinmaster
Quote from: gezgin on March 01, 2008, 04:21:26 AM
Or using 4093 schmitt NAND gate..
I have connected up the circuit, but i am getting a very samll pulse from the coil. smaller pulse than before
thanks
jason
